Won't start after front end collision
Discussion in 'Gen 3 Prius Technical Discussion' started by jwnc, Apr 20, 2022.
  1. jwnc
    jwnc New Member
    NC
    2014 Prius 3 Had front end crash about 4 months ago. Put a new fully charged battery and changed the battery on the key fob. The battery checks 12.6 at the engine compartment fuse box. The key fob won't lock or unlock doors. The lights and horn work but the dash won't light up. The power button is lit but nothing happens when pressed.
    51,154
    pretty tough to diagnose over the net. it sounds like someone needs to take a good look at all the wiring in the area of the damage.
    has it been repaired?
  3. ASRDogman
    ASRDogman Senior Member
    7,243
    3,780
    I don't remember what it's called, but after a collision, something locks that needs to be unlocked
    in the main ecu. Did the air bags deploy?
    I remember reading somewhere on Prius Chat, but can't remember what or where it is.
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I agree Especially if the airbags deployed. Hopefully more people can respond and give you more info. I believe that the main battery has a fuse. (Hybrid battery which is your engine cranking battery)
  5. Mendel Leisk
    40,584
    ^ My first thought too.
    IIRC: someone here recently had a VERY minor front end tap (just in a parking lot), the computers decided to blow the air bags, and the car wouldn't start thereafter.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Not sure about the Gen3, but the Gen 2 has a small relay(?) mounted on the driverside of the inverter that disables the hybrid system if the crash sensors detect an impact. Pretty sure that's what it's for. Been a while since I played with it.
    But, that doesn't really explain why even the dash isn't powering up. maybe damaged wiring and a blow fuse(s)?
  7. jwnc
    jwnc New Member
    NC
    The air bags did deploy.
  8. 2010moneypit?
    314
    122
    Beaumont ca
    It may need a airbag module.
  9. Dagoba
    Dagoba Junior Member
    25
    Bellingham, WA
    Airbags deployed | PriusChat
