Won't start! All my fault . . .
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shankfisher, May 31, 2008.
  1. shankfisher
    shankfisher New Member
    Searcy, AR
    2002 Prius
    It started with a small thing . . . I left the dome light on and ran the battery down in my 2002 Prius. Then, when I tried to jump start it, I crossed cables. After a minute or so the cables were very hot, and I swapped them back, to the correct way. After several minutes the car would not turn over and was totally dead. I got a replacement battery from the dealer and a 100 AMP fues, which was the only fuse blown I could find.
    Now the car has power -- the lights come on the speedometer lights up (but does not show a gear shift indicator change) and the mfd will not come on, and the car will not even try to start.
    What did I do? If it salvageable? Junk? Anybody done this and know what's up?
  2. Patrick Wong
    18,200
    6,472
    I suggest you closely examine the fuses again, keeping in mind that you have three relay/fuse boxes in the engine compartment and one fuse box in the driver's side of the instrument panel, visible when you open the driver's door.
    I don't recall whether the relay/fuse box next to the inverter has non-removable fuses built in to the box. If those pop, they probably are not replaceable and the box would then have to be removed and replaced.
    If all fuses are good and you still have a problem, my guess is that your inverter is bad and must be replaced, since the DC to DC converter has no protection against a reversed-polarity jumpstart. Unfortunately, the cost of a botched Prius jumpstart can be extremely high, into four digits.
    You may be able to purchase a used inverter from a salvage yard, which would reduce the repair cost substantially if you can DIY replacement.
  3. shankfisher
    Searcy, AR
    2002 Prius
    Thanks so much for your help. I feel like such an idiot. I don't have much money . . .
    Which fuses do i check? I've checked them all, I think. The main fuse was a real pain to take out and replace. Could I have put it in wrong?
    Is there any chance the ecu/computer modules are busted? I don't have one of the handheld units that checks error codes.
    Is this the part I need to replace?
    eBay Motors: 01 02 03 TOYOTA PRIUS INVERTER ASSY W/ DC CONVERTER OEM (item 300228788209 end time Jun-04-08 11:04:42 PDT)
  4. Patrick Wong
    18,200
    6,472
    If you are referring to the fuse that lives in the positive terminal fuse block on top of the 12V auxiliary battery, then either it is in, or it is not in. If it is not in, then you would have absolutely no power supplied to any circuit.
    It is certainly possible that one or more of the many ECUs has also failed; however I think that for the most part they have diode protection against reversed polarity.
    It would be best for you to tow your car to a Toyota dealer so that they can provide you with a list of DTCs and their diagnosis. Assuming that the inverter did fail, the eBay part that you listed should be correct.
    If you plan to replace the inverter yourself, I strongly suggest that you visit techinfo.toyota.com and download the relevant repair manual pages to improve the likelihood that you can do the job without killing yourself or further damaging the car. There is an element of personal danger involved since you will be contacting the high voltage battery cables.
    Good luck...
  5. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    check every fuse. DH would expect to see 4-6 shot. pull em out and look at em. you really don't want an inverter replacement if it was just a fuse.
    he's only seen this situation 3 times, and twice required a new inverter. the one with the surviving inverter was jumped off a jump pack.
  6. Patrick Wong
    18,200
    6,472
    I'm assuming that you replaced the 100A DC/DC fuse. Since you say the MFD does not power up, check the following fuses at minimum:
    • 10A ACC
    • 15A DOME
    • 5A ECU-IG
    • 5A AM1
    As Galaxee suggested, it would be best to remove and carefully inspect every fuse. If all fuses are good and you have installed a new battery, then the MFD should light up. If the car still doesn't start, then the inverter probably needs to be replaced.
    Please note and report the names of any blown fuses that you find.
