Won't Start
Discussion in 'Gen 3 Prius Main Forum' started by KevininFl, Nov 19, 2024.
  1. KevininFl
    KevininFl Junior Member
    61
    16
    Fort Myers Fl.
    Hello, 13 Prius won't start,Yellow triangle flashing in the bottom left corner,other lights won't come on. Innova scanner I bought at AutoZone didn't have any DTC.
    I believe battery is good I recently charged it on my Battery Tender. Currently about 170K miles on the car.Its been good.TYIA.
  2. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    Measure the voltage of the 12v battery with a meter. What voltage do you read?
    How old is the 12v battery?
    Did you try jump starting the car?
    #2 Brian1954, Nov 19, 2024
  3. KevininFl
    61
    16
    Fort Myers Fl.
    I don't have a battery meter. The battery is a Bosch 4 year AGM Battery that's 5 years old
    Charged up about a week ago.
    No,didn't try jumping it.
  4. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    You can get a meter from walfart for about $20-30. Worth the investment.
    As was stated, try jumping it. You can do that in the fuse box in the engine compartment.
    It's easy and doesn't cost anything. IF it starts, I'd say it's time for a new battery.
    Toyota makes the best one for the Prius. Whatever battery you get, I suggust charging it
    at 5 amps or less for at least 6 hours, 12 would be best. With an agm charger
