Working on the hybrid battery and we have some questions.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Spiritedfolf, Nov 3, 2021.
  1. Spiritedfolf
    Spiritedfolf New Member
    PNW
    We've been researching how to recondition and replace cells. According to the seller of some new cells, replacing old cells with brand new ones would cause the battery to be unbalanced. So our question is, should we buy used cells to avoid capacity issues? If so, where would be the best place to acquire used cells? Is there a seller that is more reputable/doesn't send out bad cells?
  2. nancytheprius
    nancytheprius Active Member
    354
    152
    iowa
    check out ebay, it is probably your best bet. Then obviously look at seller ratings and reviews
  3. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    Spiritedfolf likes this.
  4. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Here are a couple of members that sell modules and offer advice : @ericbecky and @TMR-JWAP - both have phone #'s in their profile.
    FYI : you're moderated until you've posted 5 times.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    It is my understanding for best results you must balance the pack once you put in new cells or used cells which ever way you go. You want to voltages as closest possible. The only way that I know how to do that is with a grid charger such as prolong. I have heard of people building their own but I’d be worried about overheating the battery. The idea is to charge at a very low rate for a long time. Some cells will charge faster get to their max capacity and give the extra charge off as heat. While the other ones to catch up
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,218
    5,902
    Columbia, SC
    The LeBron James explanation.....
    Inconsistent Hybrid battery readings | PriusChat
    If you've already done some testing to determine capacities of your modules, it would be very easy to provide you with modules that match your average. If you're desiring to do just a swap of the failed module(s) with no other work, and all you have is year, mileage and climate, it's a bit more of a guess, but can still be very successful. The majority of the modules I sell are matched to a buyer via the second method. I have several hundred that have been tested and documented with their capacity. A thousand more waiting to be tested.
  7. Spiritedfolf
    PNW
    Thank you! All is well after cycles and replacement of modules and balancing.
  8. nancytheprius
    354
    152
    iowa
    Where did you end up getting your cells from? any useful tips from the overall process?
  9. Gino Veltri
    Gino Veltri Member
    397
    40
    Im confused, so many places here say not to discharge below 6 volts per modules. But then i see some other people discharging eventually down to 3 volts. How can this be right? Is that 3 volts per cell?
    I also have 3 different hobby chargers, the cheap imax knockoff is garbage, but this dual port one has preset discharge voltages such that S6 is 4.8 volts. Am i damaging my modules going this low? Its actually produced some good maH numbers but im super confused by this.
    If i want to discharge to 6 volts its listed as S8, but i know there are only 6 cells in each module to Im afraid to use that setting.
    Also what should my capacity cutoff be? Im going with 6.5 just because thats the factory spec for a brand new battery. In theory this shouldnt matter because my modules are older than dirt, right? Theyll never reach close to 6.5 Ah again, correct?
  10. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Already asked and answered here and here.
  11. Gino Veltri
    Gino Veltri Member
    397
    40
    Yea, noted. Now I don’t know where to reply.
    SuzB likes this.
