Worried about starting noise
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by domeus, Jun 19, 2022.
  1. domeus
    domeus Junior Member
    Finland
    2012 Prius+ MPV
    Just noticed my 2012 prius+ (V) rattles one second after ICE startup on cold engine. Is it normal?
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    How many miles, and how is your oil quantity?
    49,494
    often, it is the very beginning of a head gasket leak, unfortunately.
    have you cleaned the egr circuit?
    Meg&Bear and rampante550 like this.
  4. domeus
    Finland
    2012 Prius+ MPV
    Total 330000km. Head gasket was replaced 30000km ago by professional. Its causing differend style rattling and shaking. New HG solved it. Also whole EGR system was cleaned. Im thinking now that the noise is coming from vvt-i.. And what I found it is normal in some situations for cold engine start.
    Im using mobil 1 0w20 oil and oil level is OK. No oil consumption on change interval, and also coolant level stays topped.
    #4 domeus, Jun 20, 2022
    Meg&Bear likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,717
    Texas Hill Country
    Does not sound or look like a head gasket yet... maybe your variable valve timing needs an oil change
    Meg&Bear and domeus like this.
  6. Air_Boss
    3,952
    1,083
    New Yawk
    Are there filters in the vvti solenoid and valuing systems? Similar issues occur on the Honda vvt system.
  7. domeus
    Finland
    2012 Prius+ MPV
    Now if im really trying to think, maybe it makes the same noise before last oil change I made. After that noise is gone. So last oil change was 8000km ago. Maybe time to change oils like @rjparker said. I will call problem solved and case closed. Thank you all.
  8. domeus
    Finland
    2012 Prius+ MPV
    Update: changed oils, and noise is now gone.
    Air_Boss likes this.
  9. Air_Boss
    3,952
    1,083
    New Yawk
    That’s the before and after on the Honda VTEC vvt solenoid, too.
    domeus likes this.
