Would a 2009 need a new 12v battery?
Discussion in 'Gen 2 Prius Fuel Economy' started by jcgee88, Feb 25, 2010.
  1. jcgee88
    jcgee88 Member
    181
    23
    Maryland Heights, MO
    I have seen the various threads that suggest that
    a weakened 12v battery can result in lower mileage, by
    causing the ICE to turn on more than necessary to
    charge that battery.
    I bought a low mileage 2009 at the beginning of
    February, and have experienced MPG that is on
    the low side of the normal range. I do intermixed
    city and freeway driving. I had been getting 43 MPG
    according to the MFD, then discovered the trick
    about inflating the tires to 42/40 psi, and now
    my overall is 43.1 MPG over my initial 160 miles.
    One thing that leads me to suspect that the
    battery is weak is that when I first power on the
    car, it almost always starts the ICE within 10-20
    seconds. In other words, even the low speed moving
    the car from a parking spot, which I sense should be
    in stealth mode, is being powered by the ICE.
    I have since tested the battery using the
    "Vehicle Signal Check" process from jdenenberg:
    Unloaded battery: 12.1v (supposed to be 12.4 to 12.8)
    Under load: 11.9v (supposed to >12v)
    Charging: 14.1v (supposed to be >13.6 and <14.4)
    These results were after the car had sat unused
    for three days. The first two measurements are
    low, the third is in the acceptable range.
    Since this is a 2009 model, I find it hard to believe I
    would need a new 12v battery. But, the measurements
    would seem to indicate that I do. And, maybe the
    car's low mileage indicates that it sat unused (which
    is usually not good for a battery) much of the time.
    Any opinions or advice?
    John
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The ICE will always come on after getting in the READY mode when the car is cold or has been sitting for a while. It's to warm the ICE for emissions control and to provide cabin heat in cold weather. What you are experiencing is perfectly normal.
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    I would test the battery when it has rested overnight, rather than after 3 days.
    firepa63 is correct, the gen2 prius will light the ICE a few seconds after Ready Mode as part of its warmup (the gen3 will skip it if engine coolant temp >60C).
    For details on the warmup process, see the links in my spreadsheet here:
    http://priuschat.com/forums/knowled...perating-mode-availability-reference-aid.html
    Keep an eye on the battery, but I think you are likely fine, just need to read on P&G, etc and get some seat time with it. 50+ will come with warmer temps and more experience.
    Good luck!
  4. Bob64
    1,540
    93
    Virginia
    Your symptoms arn't caused by a low battery. The prius ALWAYS starts the engine when you turn it on from a cold start. It will then warm up the catalytic converter to minimum operating temp, and then shut off.
  5. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    You're probably experiencing lower than expected mileage due to low temperatures, winter gas and short trips. Summer should fix the first 2, and a nice driving holiday will fix the last one.
    and Welcome.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    John, register your car at http://www.toyotaownersonline.com/index.html to see its service history.
  7. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    It's also possible that previous owner ran the battery down several times. It is a small battery and a couple of complete discharges will shorten it's life.
  8. Patrick Wong
    18,200
    6,493
    Hi John,
    If you have access to a battery charger, then I'd suggest you try to fully charge the battery using the 2A setting overnight. See if that makes a difference to the voltage readings when you've let several hours elapse after removing the charger.
    Also, what constitutes low mileage?
  9. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    In the North east in the winter time, 43 MPG is normal. You should get about 47 in the spring and summer.
  10. richard schumacher
    7,664
    1,043
    United States
    Sounds normal for conditions. MPGs will improve as the weather warms.
