Would it make sense to buy the prime if I never intend to plug in?
Discussion in 'Prime Plug-in Charging' started by jessetoedtman, Apr 15, 2017.
  1. jessetoedtman
    jessetoedtman Junior Member
    25
    San Diego
    Just as the title says. I am considering a Prime as I drive a lot for work (sales). Unfortunately my house situation would result in me almost never plugging it in.
    That said, is it still a smart idea to pursue? Any detrimenta side effects for not plugging in ever?
    MikeDee likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    nope, no side effects, the car would act like a regular prius, but with better gas mileage
    jmarkd7 likes this.
  3. Rmay635703
    Rmay635703 Senior Member
    2,580
    1,601
    Somewhere in Wisconsin
    2013 Chevy Volt
    Easy answer after tax breaks is the prime about the same cost as the Prius IV you were going to buy anyway?
    Is a green sticker /HOV access worth something?
    The Prime is a better car than a normal Prius in a variety of ways (except for the elevated floor)
    No brainer in my mind.
    That said my first car long ago was electric long before anyone else drove electrically , I have always lived in apartments, never had a situation where I couldn't find a way to plug in.
    Maybe I just know how to grease wheels but I doubt it, my guess is it's a will/way situation
  4. jessetoedtman
    25
    San Diego
    Thank you for the replies. The prime is less expensive for me and I like everything about it except for a) less cargo space and b) no spare tire (irrational as I haven't had a flat in 15 years).
    HOV access is worth a lot to me as well given I am on the road solo often.
    I just wanted to double check and make sure I'm not missing anything.
    Also curious- as far as resale, how does everyone think these will hold up?
    jmarkd7 likes this.
  5. Rmay635703
    2,580
    1,601
    2013 Chevy Volt
    Well after tax breaks and incentives your paying what $20000?
    The old saying is you loose half the cars value as soon as it leaves the lot seems true so $10,000?
    I have never gotten more than $1500 for a used car regardless of age or miles. Since those experiences, My belief is to drive until rust out since I've never had success at getting anywhere near bluebook. In terms of trade ins I get the same deal with or without trade so figure the dealer is offering $0.
    In the end nobody knows, your car is worth more if gas goes up less if it stays low.
    Ah well, good luck
  6. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    You may wish to add c) no rear wiper and d) only a 4 seater. We, however, think the advantages of owning a prime may very well out weight the disadvantages.
  7. Crowmag Naman
    Crowmag Naman Junior Member
    29
    albany new york
    Also the battery is huge compared the the regular hybrid. I assume it will far outlast the regular hybrid battery.
  8. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    Considering resale, if you're getting ~$4K off in incentives for buying it now, as soon as it's used you have to deduct that same $4K in addition to normal depreciation. The original PIP isn't holding its value very well but that partly is because it was probably overpriced to begin with. Since the prime is coming out cheaper initially, I bet the prime will do better except for the incentives I just mention and if they release a better prime with 5 seats, a longer range, or a flat hatch in the near future. EVs don't always hold their value well because of battery concerns and rapid improvement of the technology obsoleting older ones quickly.
    It does sound like it would fit your use case really well though. Most of its weaknesses are diminished by a single person driving it a lot. Of all the plug ins, it's probably the best one to get if you don't plug in because it is so efficient in all modes. Good luck!
  9. jessetoedtman
    25
    San Diego
    Ah yes. Forgot to mention the fifth seat. I can't remember the last time I had 5 in my car, but for some (again irrational) reason, it scares me. The lack of a rear wiper doesn't scare me too much as I don't think I'd use it often living in socal- plus my current vehicle is a Tacoma with a top on that I can't see out the back anyway.
    I'm going to test out the trunk with a cooler in it to see if it will fit for when I do long rock climbing trips. Can't wait to find out! Thanks for everyone's feedback!
    jmarkd7 and Kramah313 like this.
  10. Since2002
    Since2002 Senior Lurker
    936
    1,097
    Duluth, GA
    The traction battery would be running less than half full all the time, maybe not good for battery life? If so then might want to run Charge Mode every once in a while if there aren't any other places to occasionally plug in and charge. I guess it depends on what "almost never plugging it in" means.
  11. Rmay635703
    2,580
    1,601
    2013 Chevy Volt
    Lithium batteries age most slowly near "empty"
  12. Kramah313
    408
    322
    Dallas, TX
    Situations can change also. Maybe you can't plug in now but in the future you might be able to more. Could grab EV parking spots or the occasional free charger too (if such things ever exist in California - I know there are more EVs there than there are here in Dallas)
    jmarkd7 and Rmay635703 like this.
  13. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Prime probably shines as a commuter car, so I do not see any problem, except loss of spare tire if you are putting lots of miles on. Cruise range between fill-ups is great on Prime.
    As far as HOV, I am not aware of any Northeast state HOV lanes which require plug-in over hybrids, so regular Prius should be OK in most areas. NY/NJ may require 45 MPG vehicle to get into HOV/green EZ Pass, if I recall.
    #13 wjtracy, Apr 16, 2017
  14. El Dobro
    El Dobro A Member
    6,972
    3,209
    I lost the rear wiper when I went from the Prii to the Volt and haven't really missed it.
  15. mdhare
    mdhare Member
    58
    33
    Madison, WI
    Recently bought an EGO lithium cordless lawnmower. Manual recommends charging to full at least once every 6 months. Battery pack discharges to 30% after 30 days of inactivity.
    I am not a chemist but given charge mode gives you a way to accomplish without a plug (at least close to full) probably not a bad idea.
  16. Since2002
    936
    1,097
    Duluth, GA
    I would guess that's mainly to keep the battery from completely discharging. But the Prime's battery would never get anywhere near total discharge even if you never plug in, since you would be in HV mode, and that's on top of a built in cushion. Only if you didn't drive it for a long period of time would there be any risk of discharging the traction battery.
    My question was whether it is detrimental to battery life if the traction battery is never more than say half full. But since there is also a top-end cushion then I guess probably not.
  17. Mendel Leisk
    38,247
    In your shoes, I would stick with a regular Prius.
    Lightning Racer and breakfast like this.
  18. Rmay635703
    2,580
    1,601
    2013 Chevy Volt
    Just a poor design
  19. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    Just my 1.9 cents, but you never know what the future holds. If you are planning on owning for a while, your situation may change. Being on the road a lot you can find charging stations. With a little effort you can get 60+ mpg without charging. If it was me, I would get the Prime. Oh wait, I did. (y)
  20. mdhare
    mdhare Member
    58
    33
    Madison, WI
    Care to elaborate about which part of my comment you are referring (genuinely interested)? Toyota also recommends against holding full charge for a lengthy period of time so discharge to 30% after one month seems inline with longevity. I guess I didn't mention it was an intentional discharge to 30% after prolonged idle by conversion to heat, not drop to 30% by phantom losses
