Would ramps work with prius ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lowspeed, Mar 7, 2006.
  1. lowspeed
    lowspeed Member
    267
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Can't say for sure, but i remember seeing a picture of someone using similar ramps for their rear wheels when installing the BT plate.
  3. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    Seems I saw this before, I think the poster stated they had to use floor jacks as the front catches on the ramps..
  4. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    My ramps look like the ones you are considering and they work - just barely. See picture
  5. lowspeed
    lowspeed Member
    267
    Wow, that is close :) But seems to work! I think i'll go with that.
    Thanks for the picture.
  6. dreichla
    dreichla New Member
    2,230
    Connecticut
    I have a set of steel ramps - similar pitch to the ramp above. It just barely works. My ramps actually have a 1'' curb on either side of the incline which brings it closer to the cowling. I need to position the ramp carefully to get the maximum clearance.
  7. jtullos
    jtullos New Member
    172
    Dayton, NV
    I don't remember how close my ramps were, but they worked. They look similar to the ones you're showing, and I think they're the same brand, but rated for a lower weight (8,000 lbs, that's plenty for the Prius).
  8. etyler88
    etyler88 etyler88
    450
    Dover, DE
    I use those exact ramps, no problems.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I have an old pair of steel ramps and they do *not* work on my Prius. I have to jack it up and use safety stands.
    If you're buying the ramps for oil changes, I don't think you have to. It's a tight fit, but you can change the oil with all 4 wheels on the ground. I've done it twice now.
  10. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I have steel ramps that don't quite fit so I cut some 2x10s to act as extenders. I first drive up on the wood and that gives me enough clearance to make it up onto the ramps.
  11. darelldd
    6,059
    389
    Northern CA
  12. Bill P
    Bill P New Member
    17
    Windham, NH
    Those look like the very same ramps that I used to lift the rear of my 05 Prius earlier today to install the BT Chasis Stiffening plate.
    They worked like a charm on the rear of the vehicle.
    I believe some posters have reported that they might not work on th front wheels...haven't tried them there yet.
    I use ths same ramps to change the oil and work on my John Deere tractor. They really are very sturdy, yet light enough to handle, and they really come in handy.
  13. KTPhil
    KTPhil Active Member
    1,379
    I also use them when changing oil. They scrape, but I avoid this by lifting on the front end just before driving up them. I also back down slowly.
  14. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    My generic steel ramps just *barely* fit under the bumper plastic
    to get in position -- I have to pull up on the car and let the
    bumper bend just a little, but it's enough to drive forward and up.
    But if the tires get damp somehow, they'll *slip* on the ramps which
    makes it much harder to get up there.. should do the Wood Thing.
    http://techno-fandom.org/~hobbit/cars/naked/spread.jpg
    _H*
  15. Kaos1
    Kaos1 Junior Member
    Mid-Alantic
    I have a set of ramps that I made 20 years ago out of a 6X6. It was about 4 feet long and I cut a nice long diagonal slope through the middle leaving a good 10" on both ends. They have served me well and I sure have got my money out of them. They have supported everthing from the Prius to a 3/4 ton pickup truck. You can custom make a set to any slope you want.
    Kaos1
  16. oldguy#4
    oldguy#4 Junior Member
    Central Florida
    Darn! I thought I was so cleaver when I rigged mine up. Also notice in the photo that I took them seriously about the extra four tenths of a quart.
