Would these tires fit the prius ? 205/55/R16
Discussion in 'Gen 2 Prius Main Forum' started by lowspeed, Nov 7, 2007.
  1. lowspeed
    lowspeed Member
    267
    Thanks.
  2. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    <div class='quotetop'>QUOTE(lowspeed @ Nov 7 2007, 08:17 PM) [snapback]536455[/snapback]</div>
    Yes, provided you have 16" wheels, which are standard on the Touring Edition.
    You should check out this thread entitled "Touring Edition Tire Upgrade" and which I've linked for you here:
    http://priuschat.com/index.php?showtopic=3...hl=tire+upgrade
  3. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    lowspeed,
    I have an '08 Touring Prii and when my 195/55R16's wear out, I am planning on buying 205/55R16's to replace them. Both Goodyear and Michelin as well as others make this size of tire. I am leaning toward the Michelin Harmony tire for replacement on my '08 Touring Prii. So to answer your question, If you have a Touring model, yes, they will fit the Prius. I can't speak for the standard model with the 15 inch wheels.
    Slide
  4. lowspeed
    lowspeed Member
    267
    <div class='quotetop'>QUOTE(Sliderule @ Nov 7 2007, 08:51 PM) [snapback]536471[/snapback]</div>
    I don't have the touring model. Should that matter ?
  5. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    <div class='quotetop'>QUOTE(lowspeed @ Nov 7 2007, 08:25 PM) [snapback]536486[/snapback]</div>
    lowspeed,
    I believe Pinto Girl has a standard Prii that she replaced the 15-inch wheels with 16-inch wheels without any problems. Standards have 15-inch wheels and Touring models have 16-inch wheels. You might PM her and see what see did. When upgrading to the 16-inch wheel, you will need to make sure the larger wheel size and rims you chose will fit in the wheel well without rubbing. Other PC members that have upgrade to larger wheels can give you better info on the do's and don'ts. Any comments from those that have gone to the large tire size ?
    Slide
  6. lowspeed
    lowspeed Member
    267
    Markzaca likes this.
