Would this adaptor work?
Discussion in 'Prime Plug-in Charging' started by Lynkdev, Jan 17, 2021.
  1. Lynkdev
    Lynkdev Junior Member
    25
    Would this work?
    My house came with a 240 plug outside for previous owners tesla. Replacing the plug with this one and already merged the female receptacle with the cord.
    Will be using with the 2017 Prius Prime charger that came with the car. View attachment 204113 View attachment 204114 20210116_130952.jpg
    SM-N986U1 ?
  2. Lynkdev
    25
    SM-N986U1 ?
  3. Lynkdev
    25
    SM-N986U1 ?
    52,384
    you might need to change something in the brick, i'm not sure. otherwise, looks good.
    see @Rob43 thread: 'using prime charger for 240v for $20.'
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    I'm confused. You're taking a 240v outlet/wiring and attempting to adapt it to a 120v plug/system? Isn't the oem charger for a prime designed for a 120v outlet?
    If you are essentially taking each socket of the 120v plug and wiring it to each socket of a 240 volt plug, you're fabricating a 120v outlet that has 240 volts on it. You are going to smoke the heck out of anything you plug into it.. make sure your homeowners insurance is up to date.
    #5 TMR-JWAP, Jan 17, 2021
  6. Lynkdev
    25
    I'm replicating what was done here
    SM-N986U1 ?
  7. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Exactly - You have a 120V socket taped to a 240V source. Let us know how that works. We'd prefer to see a video of when you first use it.
  8. fuzzy1
    10,602
    Did you both miss this thead?
    Using the Primes 120v Charger at 240 Volts, Cost $20 !!! | PriusChat
    Yes, serious caution is necessary because this will not work out well for 120V-ony items mistakenly plugged in to it. That is why these code-nonconforming adapters are not commercially available, they must be hand made. But plenty of Prime owners here have found great success with them for recharging their Primes.
    jerrymildred and Lynkdev like this.
