Would you replace your water pump?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Nov 27, 2020.
  1. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    I hate trying to fix things that aren't broken. But I am sick of hearing this water pump issue. I recently met a guy I haven't seen for a long time. He also was driving a Gen3 Prius. We shared how much we love this car and what we (each) had done to it. I got everything done from his check list except the water pump. He insisted several times that I should replace it.
    My car (2010 Prius III) is about to turn 180k. So far so good. I have done some maintenance, sparkplugs, intake cleaning, EGR system (including the cooler) etc. Also have the oil catch can. That's it about the engine.
    Part of me wants to replace the pump and part of me absolutely does not.
    How does this damn thing break on you? Does it soft fail or hard fail?
    Are there any warning signs?
    I would appreciate if you contribute and let me make up my mind on this.
  2. JC91006
    16,673
    8,518
    If you plan to keep the car for 5 more years, change the water pump now. It'll be a 1 time replacement.
    Any car with nearly 200k miles will need parts, this car isn't any different
    pjksr02 and ASRDogman like this.
  3. iskoos
    403
    251
    Orlando, FL
    Thank you. Water pump isn't the only part that may fail when reaching 200k though.
    I will not keep this car for another 5 years for sure. Probably a year or two more before trying to get a Gen4.
    I am trying to figure out how it fails. Will I have a chance to get to my destination (if not too far) or I will need a tow truck?
    Ones that experienced this could probably tell me :)
  4. AzusaPrius
    AzusaPrius Senior Member
    2,137
    904
    If the waterpump is not throwing a code for it then you are good for now.
    Once you get the code just swap it out it is very easy and if you search right you can find one for $125 on ebay.
    You will not get an overheat warning and the car will eventually stall on you and cut the engine off.
    Usually it fails when people pour a leak fix in the coolant.
  5. iskoos
    403
    251
    Orlando, FL
    Thank you. Yes no code or any sign whatsoever so far. Otherwise it would have been replaced by now. I checked the videos. The only difficult (maybe messy) thing is the coolant/flush. My head gasket is good (so far:cool:). I do not have any need to use those leak fixes.
    You said "You will not get an overheat warning and the car will eventually stall on you and cut the engine off."
    Can you please explain what you meant by that? Did you mean I WILL get an overheat warning.
    Does Prius shut off the ICE when the water pump fails? If so, that is an excellent feature.
  6. AzusaPrius
    2,137
    904
    Yes this is what happend to me when my waterpump failed, the ICE just shut down and total loss of power.
    You can have the code for a while but eventually it will fail like that and you will be stuck unless you have a code reader to reset to the codes.
    Trust me though, you dont want that to happen, I was lucky and was down the street from my house.
    I had to continue to reset the codes like 10 times just to make it home.
  7. AzusaPrius
    2,137
    904
  8. iskoos
    403
    251
    Orlando, FL
    I see. But to be honest with you, I prefer the ECU to shot down the engine than dealing with consequences of overheating.
    I have a code reader (several kind). Resetting it no issue.
    So let's recap once again: In your case, you had a code but no warning (This is strange) and the ECU shot down the engine to prevent any more damage. You were unable to restart the engine till you clear the code. Am I following you right here?
    What code did you get?
  9. AzusaPrius
    2,137
    904
    P261B is the waterpump code and the whole dash lights up like a christmas tree but there is no "overheat" light.
  10. iskoos
    403
    251
    Orlando, FL
    Was the old pump motor seized?
  11. AzusaPrius
    2,137
    904
    Yes it was not spinning as freely as it should and it was the original so it had like 180k on it.
  12. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    Is it really a water pump issue? Or a friend issue? I mean there must a reason why you havent “met” him “in a while.”
    tony_2018 likes this.
