WOULDN'T IT BE NICE (AND SMART)............
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FloridaWen, May 21, 2007.
  1. FloridaWen
    FloridaWen New Member
    573
    Plant City, Florida
    ......... if the Toyota Prius could indicate REAL, ACTUAL "MILES" on the ICE (gasoline engine) as well as HOURS on the electric motor. The purpose of the "actual miles" on the gasoline engine would be extremely helpful (in MY opinion) for OIL/Filter Changes, etc. After all, a Prius that does almost all highway driving would have the ICE "on" much more than in city "stop-and-go / bumper-to-bumper", right ?? This would take the "guesswork" out of how many "actual miles" does the ICE stay on for over a period of time......... I am an Electronic Engineer and we just picked up our new 2007 Prius Touring (pkg. 5) only FOUR DAYS AGO, but as a passenger (yep, it's the Wife's new vehicle) I sat in the passenger's seat watching the "Energy Meter" display, showing when the ICE kicked in, when the "motor" was running and when the vehicle was "coasting and charging", etc. So...... the computer KNOWS all this info. therefore it can just have a modified program to actually SHOW the user (driver) the real, true specs. (miles / hours) !! :D
    Is this a good idea or not ????
  2. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Not a bad idea, but I think for the average user the ICE will be "on" for most miles driven. It's only at speeds below 41 mph and using pulse & glide you would get the prius to not spin the motor when coasting. At higher speed it will spin the ICE (even if the display doesn't show it) using the battery instead of gasoline (when it can) as to be ready to accelerate the car.
    So overall the ICE will be on for most miles driven for the average user, even if it doesn't use gas all the time.
    I think for a plug-in hybrid or the next gen hybrid with (rumored) 9 miles EV range it would make sense to have this info.
  3. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Why would it? I think more appropriate is an hour meter for the motor, like on airplanes.
  4. Swanny1172
    Swanny1172 New Member
    666
    I think it would be a nice feature to have for the simple fact that I think having more information is never a bad thing. It would be interesting to see what percentage of the time the car is running on EV power versus ICE power. I think such a measure would be effective in helping a new driver learn the hybrid system and maximize their efficiency in operating the car. The Prius does drive differently than any other car and has a bit of a learning curve. Having more information at your disposal would just help speed the learning process.
  5. SomervillePrius
    944
    Somerville, MA
    I like the hour meter for the motor. For next-gen hybrids this might be the appropriate measure. The VOLT for example would surely need it as if I had one I would rarely use the ICE at all. Event for a next gen prius with (rumored) 9 miles EV an "hours used" for the ICE might make a better meter then mileage.
  6. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(FloridaWen @ May 21 2007, 09:17 AM) [snapback]446589[/snapback]</div>
    Well, we've all managed for the past 80 years without a seperate tally for "highway miles" versus "city miles". A engine in a conventional car does a lot less work per mile at highway speeds than it does at city speeds. Yet we've managed to survive with only one odometer.
  7. FloridaWen
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(Marlin @ May 21 2007, 10:27 AM) [snapback]446624[/snapback]</div>
    I guess YOU have totally missed the point.................. PRIUS is NOT a "conventional" gasoline ONLY powered vehicle.......... therefore the ICE (gasoline engine) is NOT "on" ALL the time, ALL the MILES........
  8. Frank Hudon
    Frank Hudon Senior Member
    4,147
    this is a shot of the MFD in the wife's 2k4 after a trip that we took last year. Notice that the ICE ran only 68% of the time on the trip. I posted this question last year but deleted all the pix's in my folder so have reposted it.
  9. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(FloridaWen @ May 21 2007, 10:39 AM) [snapback]446634[/snapback]</div>
    And I guess YOU have totally missed the point too. In a conventional car, there is a difference between "city miles" and "highway miles" on the wear and tear of the engine. So, a car that spends it's time running up and down the east coast on the highway does not put as much wear and tear on a engine in 3000 miles as a car that spends all it's time driving around New York City for 3000 miles. Its the same issue, just different circumstances. Yet somehow we've managed for the past 80 years not to need to seperately track the different types of miles in order to perform routine maintanence such as oil changes. That was the point YOU missed.
  10. FloridaWen
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(Marlin @ May 21 2007, 10:46 AM) [snapback]446642[/snapback]</div>
    OKAY, NOW I get ya'................. (sorry)........... But please remember that with a "conventional" gasoline ONLY vehicle a "smart" owner will sort of "average out" these factors.............. in other words, if "I" (as a real example) take a long trip, say Florida to Connecticut then back, I "KNOW" these are "highway miles" as compared to if I used that vehicle for "city" driving.......... then with the latter, I would change my oil (and filter) much more frequently.
    The point I am trying to make about the PRIUS is that many owners "see" 1,000 MILES on the odometer and this is the magic point MANY want to remove that initial (factory) OIL used for "break-in" along with the filter. Now doing this and putting back regular "fossil" oil is a great thing.............. but to put back a synthetic motor oil at 1,000 "odometer" miles is REALLY like 500 to 750 ACTUAL MILES on that gasoline (ICE) engine !! If synthethic motor oil is put into the Prius TOO SOON that is NOT GOOD either..........
  11. PA Prius
    PA Prius Active Member
    763
    251
    SE Pennsylvania
    My request for something "nice and smart" would be for a lifetime average mpg indicator. I think this should be on all vehicles. It would give used car buyers an inclination of how the car was driven and may just encourage most drivers to drive more economically.
    PA P
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    We've had this "Hobbs meter" discussion before. I, too, feel that more important and useful would be a "hours on the ICE" meter than a "miles on the ICE" meter...for the reasons Marlin mentioned. Someone who drives more highway miles would put less where and tear on the ICE but run it for more actual hours. The Hobbs would be the answer.
    While a nice curiosity I see no use in knowing how much the MG is running...esp. since it runs almost continuously unless you're at a complete stop....and which MG do you want to know and what would you do with the information? Pointless and confusing for me and everyone.
    The point mentioned about the Volt is an interesting one. With all the nay-sayers about GM's commitment to the Volt, I think they're neglecting to factor in the 'hybrid factor'...testing the safety of new battery technology. Working through issues such as an ICE that may never run or run only once every few months and how to prevent problems related to that must be worked out. I suspect that there will be some automatic timer that will have the ICE run/idle or will, at least, alert the driver to initiate a run (push a button?) every 250 miles of driving or every week or some such. They're going to need to do extensive testing to determine how much is necessary to sustain it. Not trying to hijack this topic, but I think the point is significant and interesting.
  13. Swanny1172
    666
    <div class='quotetop'>QUOTE(FloridaWen @ May 21 2007, 10:59 AM) [snapback]446649[/snapback]</div>
    Please explain.
    There are plenty of cars that come from the factory filled with synthetic oil. I don't see how switching the Prius over early (1,000 miles) would present any problems. Heck, you could drain it as soon as you got it home from purchasing it and start running synthetic then and it wouldn't create any problems other than probably wasting some perfectly good oil.
  14. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(Frank Hudon @ May 21 2007, 07:41 AM) [snapback]446637[/snapback]</div>
    scangauge I assume?
  15. FloridaWen
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(Swanny1172 @ May 21 2007, 11:18 AM) [snapback]446664[/snapback]</div>
    Well I am just repeating what I heard from SEVERAL mechanics as well as a very smart salesperson (ex-mechanic) at the dealership we bought our new Prius at. They ALL "claim"...... that "fossil" (regular) motor oil allows a brand new engine to "scuff and wear-in" and they say FULL Synthetic is so "lubricating" (for lack of better word) that it DOES NOT ALLOW a proper "break-in" if put into a brand new engine too soon !! This is just what I heard (and read on other forums) ........... I am NOT an expert by any means, just an ex-mechanic, "ex-gearhead" from the "old school"........... late 60's through 70's....... the MuscleCar era B) !!
  16. Swanny1172
    666
    There are a lot of misconceptions about synthetic oil floating around out there and some of them die harder than others. It was common years ago for engine manufacturers to recommend non-detergent oils for engine break-in. This was when the pistons used cast-iron “square-faced†rings and the rings needed to wear some to “seat†into the engine. With today’s technology of oils and engine manufacturing, engine manufacturers no longer recommend the use of non-detergent oils for the break-in period.
    In fact, most high-end cars are coming from the factory filled with synthetic, so this obviously is not a concern that the OEM's have. I used to hear about synthetic oil causing leaking seals and the like, but that has all been proven to be bunk.
  17. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(FloridaWen @ May 21 2007, 03:05 PM) [snapback]446868[/snapback]</div>
    Your age is showing! ;)
    Seriously though, this is pretty outdated info. Today's ICEs are finely machined parts and break in just as well w/ synthetic or dino. also, there used to be issues w/ gasket degradation when a change to synthetic was made, but that too is a thing of the past.
  18. FloridaWen
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(efusco @ May 21 2007, 04:20 PM) [snapback]446879[/snapback]</div>
    Tell me about it.......... a Computer / Electronics Engineer, 54 years old and can't find any "solid" work in the field. The "youngsters" (25 - 35) are grabbing up all the high-tech computer and electronic jobs from me :( but look at the bright side.......... I can "surf" PriusChat all day long now !!
    Now to be really serious, and I KNOW there are several threads in PC about this........ so I don't want to go OFF TOPIC, but....... we have a four day old '07 Touring (pkg. 5) and I am very, very "fussy" about vehicle break-in. When would YOU (I understand this is just YOUR personal opinion, not a debate !!) suggest I take out the "factory" oil, change oil filter and switch to MOBIL1 ??
    My "good friend" a certified Mechanic (not Toyota) suggested I change the PRIUS at 3,000 MILES !!
  19. Swanny1172
    666
    FWIW, I switched over to Mobil 1 5W30 at 4,750 miles (first oil change).
    I think you really need to balance what is most important to you -- removing any possible contaminents (metal shavings, sand, etc.) from the manufacturing process as soon as possible, or listening to what you heard at the dealership and allowing the engine to get broken-in before switching to synthetic. If you are worried about the contaniments, then switch over at around 1,000 miles. If you aren't, wait until 5,000. Either way, you are going to be fine.
  20. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(FloridaWen @ May 21 2007, 03:29 PM) [snapback]446890[/snapback]</div>
    I did mine at 3000 miles...went to Mobil 1. I've had one change to dino (accident by the dealer...long story) and back to Mobil 1 since. I can't say there's any valid reason to do that, but it make me feel better.
