WOW! over 100,000 miles in my Prius II No Problems
Discussion in 'Gen 3 Prius Main Forum' started by Mark8007, May 11, 2015.
  1. Mark8007
    Mark8007 Junior Member
    25
    Fort Wayne
    I have driven my Prius over 100,000 miles and have had no repairs!!! (just new tires and oil changes) This have been the most reliable car I have ever owned. THANKS TOYOTA
    ImranAs'hab, orenji and matt b. like this.
  2. nedear88
    nedear88 My 1st Prius.
    245
    140
    San Bruno, California
    Mine past 117k+ miles still on the original set of brakes, 3rd set of tires. change the CVT fluid at 85k miles, changed the spark plugs at 105k miles, recently change coolant for the ICE and inverter. That's pretty much it beside the regular oil change, filters change etc.
    #2 nedear88, May 11, 2015
    orenji and Mark8007 like this.
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    I would think by 100K miles, you should change your spark plugs, brake fluid, coolant, trans fluid, etc. (We did all this on our 2005 when it went over 100K) Still, these are very economical cars to maintain. Trouble free.
    Mark8007 likes this.
  4. Mark8007
    25
    Fort Wayne
    Dealer told me spark plugs at 130,000 . But I do need to do a coolant and Inverter change and trans-axle change.
  5. nedear88
    245
    140
    The sparkplugs looks fine even at 105k miles, but the coolant is needed for the ICE, the inverter seems fine but I changed it anyway. Dealer will charge you twice for the coolant, since they consider the inverter is a separate coolant system.
    The spark plugs change isn't easy, you need to remove the wiper assembly/motor/tray in order to access to the ignition coils/spark plugs. It's time consuming. here is the youtube video someone post it. hope this give you an idea.
    Okinawa likes this.
  6. law
    law Member
    188
    33
    CA
    I've never changed spark plugs in any of my cars and they still all run fine. I have Ford, GMC, and Jaguar. Ford is at 250,000 miles.
  7. Fore
    Fore Don't look back!
    494
    107
    Yes, your car will keep running but your mileage will suffer in the long run!
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The spark plugs will eventually fail -physically-. If that happens those wonderful ceramic parts fall into the engine. The piston isn't impressed. It won't be warranty. Go ahead, leave them in too long if you dare! ;)
