Wow - suddenly got back 0.9mi EV after being out for a couple miles
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by calbear, Apr 12, 2012.
  1. calbear
    calbear Member
    180
    30
    SF Bay Area
    Got off the freeway with 0EV, car switched to standard HV. Drove stop and go for another couple miles with gas and some EV coasting (in the green on eco mode).
    Then, all of a sudden, the EV meter popped up to 0.9mi remaining and let me switch back into EV mode for real . Used up about half of it before parking.
    Very, very interesting... must have something to do with its estimation routine. Recently, my max EV has been about 1 mi less because someone else drove the car a few times in the past week and must have messed up my calculations not following my max fuel economy driving style.
    And maybe that data just got expunged while I was driving or something, but that's a big chunk to suddenly get back while driving (and already out of EV).
    Anyone experience this or have an idea why it happened?
  2. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
  3. calbear
    calbear Member
    180
    30
    SF Bay Area
    Thanks for the link. I've read it, but still slightly confused... I'd used up the EV completely, not 0.1mi remaining. I've definitely seen it hover at 0.1mi range for a lot longer than 0.1 miles driven - figured it was just an estimate, so it gets down to 0.1 range and stays there until you're certainly out.
    But in this case, I was out of EV and had been driving on HV for about 1 mile when it popped back up to 0.9mi EV range. And I've seen where it's come back out of HV into EV with 0.1 or 0.2 regenerated, but this was a 0.9 direct step.
    huh.... [​IMG]
  4. usdmattiphone
    usdmattiphone Member
    147
    58
    Mine has done that too. I think it happens when your ICE comes on to warm the engine to the 130 for the emissions, but during that time your engine isn't being taxed due to coasting or really low demand on either the ICE or the EV motor, so it has to spin off the excess energy into your batteries. Since the ICE has to keep running for the emissions, it won't allow you to go back into pure EV mode until this is completed. Once the warmup cycle is completed, it sees you have enough stored battery to allow a stint in pure EV, thus the sudden jump in available miles.
  5. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    John's Stuff - Toyota Prius Personal Log 560
    3-27-2012 PHV Video.
    "I forgot that turning on the outside vent would result in a lower EV capacity value being displayed on the Eco-Meter. Ugh! It automatically assumes a loss from climate-control usage, revising the estimate shown to a lower value. So when I got to the halfway point, I turned it off (note the 0.7-mile increase)."
    or you were stopped long enough for a no or little load battery voltage sample to be taken and the EV range to be updated with this actual value? Perhaps for the reasons stated in your post this just happened to be a significant correction this time.
  6. krishkal
    krishkal New Member
    Fremont, CA
    I am confused by this. Whether I have it on outside vent, or recirculating, the EV capacity is the same. Am I missing something?
  7. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Its Fan On vs Fan Off, not Recirculate vs Fresh air
    If you have it on, you will lose (estimated) range.
  8. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Once the fan is on the computer seems to think your going to use AC and reads about a mile less on the display. If you do turn the AC on you'll notice it doesn't drop more.
  9. LenP
    LenP Member
    257
    69
    Morris County, NJ
  10. calbear
    calbear Member
    180
    30
    SF Bay Area
    And now I'm trying to replicate it, and can't... :-( Tried playing with the HV button while 0.1mi EV remaining is showing, but can't get the 0.9 to pop back up again...
  11. lensovet
    2,614
    495
    Burlington, NJ
    This just means that you were able to regen enough energy that the battery charged up high enough for the car to determine that there's sufficient capacity to enable EV operation.
    You might be interested in my thread about this topic: http://priuschat.com/forums/toyota-...tery-while-driving-my-plug-in-experience.html I started with an effectively fully-discharged battery and ended up getting nearly 10 mi of all-EV range in the course of a 3-day trip.
  12. lensovet
    2,614
    495
    Burlington, NJ
    also, to your point specifically about 0.9: when you're in HV mode, it will not switch to the EV-mode battery display until it has at least 0.9 mi of estimated range remaining. It will not actually engage EV mode until you get ~2 mi of estimated range remaining.
