Wrench light appears on dashboard-Hybrid Battery Cooling System Service needed- how much is this any
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Sunfacegil, Jul 29, 2018.
  1. Sunfacegil
    Sunfacegil Junior Member
    2015 Prius V with 45,00 miles- Wrench light appears on dashboard - Manual says Hybrid battery cooling system needs service. Is this normal at 45,000 miles, how much should this cost or is it covered by my 100,00 mile certified used car warranty?
  2. camp1019
    camp1019 New Member
    Los Angeles
    2015 Prius v wagon
    51,719
    make sure the intake grille(s) are clear.
  4. eskay247
    eskay247 Junior Member
    2015 Prius v wagon
    I know this is an old post, but did you ever get your issue resolved? If so, how?
  5. Mendel Leisk
    41,149
    Original Poster never came back.
    I would start by cleaning the hybrid battery fan, it's the most likely cause.
    How many miles on it, and do have shedding pets in the car?
  6. Willh5080
    Willh5080 New Member
    UK
    It's really interesting question. Hope, somebody will share their experiance and knowlege. Simetimes i saw wrench light on my dashboard, but then it go missing. It's strange.
  7. skeptic7
    skeptic7 New Member
    Fairfax, VA
    2015 Prius v wagon
    I'd like to try to clean my battery fan and filter. I'll have to start by cleaning off my back seat. What is the name of the tool used in the video to remove the clips? Where can I get one? I've been getting errors about the battery cooling system on long trips during the last month but the message goes away the next day after the car cools down.
  8. Mendel Leisk
    41,149
    You have a Prius v? If it’s similar to 3rd Gen hatchback Prius, it’s not necessary to remove the rear seat cushion:
    HV Battery Fan Cleaning | PriusChat
    also see video #21 here, the @NutzAboutBolts video. They remove the seat cushion, but again, not necessary:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    #8 Mendel Leisk, Jul 28, 2024
    Air_Boss likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    9,999
    6,185
    Texas Hill Country
    One of the many reasons a v is better than a hatchback is it only takes one easy 10mm screw to access the hv battery fan. Mostly due to the sliding and reclining rear seats.
    #9 rjparker, Jul 28, 2024
  10. skeptic7
    skeptic7 New Member
    Fairfax, VA
    2015 Prius v wagon
    Thank you. I was never able to get the front cover off the battery. The 10mm socket bolt on the passenger side came off easily and I was able to loosen the cover on that side. I couldn't get it off the other side and didn't want to pull too hard for fear of snapping things. However I vaccuumed the car throughly paying special attention to the intake grill for the battery fan. I've gone on a long trip in hot weather reaching 88 degrees in the afternoon. The battery cooling system message did not come on so this probably fixed my problem. I'll try again to open up my car and actually look at the battery fan and its intake pipe.
