Wrong size tire on car!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by warphion, Jul 13, 2017.
  1. warphion
    warphion New Member
    Palo Alto
    I was just told by a mechanic that the tires that we have been using are the wrong size, 185 versus 195, for our 2010 Prius. The mess up must have happen a couple of years ago, when I had all tires replaced and did not check the work. We recently had to get 2 new tires after our Prius had a flat and we went with the sizes on the car, not realizing the mistake that had been made.
    The two remaining tires seem to be an issue as well and there is wear on the inner tire that is causing road noise. I am not sure if this was because the tire was smaller than the car spec or some work the mechanic fixed by in the rear wheel hub.
    Any tips on how I should proceed would be appreciated!
    thanks!
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    size only affects speedometer accuracy not wear, just keep driving until the tires wear out
    Lightning Racer likes this.
  3. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I think driving with 2 tires with one size and another 2 with another size will create problems as ABS, Traction Control, etc will sense wheels are spinning at different speed. Off size tires will not cause uneven wear, so you may also want to look into alignments for inner tire wears.
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Just move the smaller tires up front to wear them out faster so you can replace them sooner to match the rears. Uneven wear isn't caused by this. You may need a 4 wheel alignment to prevent that happening again on your next tires.
  5. FuelMiser
    FuelMiser Senior Member
    1,342
    922
    Monument, CO
    The difference between a 185/65 tire and a 195/65 tire is negligible. The tread on a 185 tire is 195 - 185 or 10 millimeters (mm) narrower. That's 0.4 inches narrower. The car on a 185 tire will also sit (195 * 65%) - (185 * 65%) or 6.5 mm lower. That's 0.25 inch lower. You'd be hard pressed to notice with the naked eye. The 185/65 tire size was the OEM spec on Gen 2 Prius, so drivability is essentially the same. If you ever end up needing four tires, then I'd say you might want to go up to 195/65, but if you're only changing two tires, stick with your current size. Keep all four tires the same size. And put the newer/better tires on the rear, regardless of front-wheel drive. Always have the better tires on the rear.
  6. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Well, I would check very carefully the load rating of the smaller tires. They will probably wear faster and be closer to the "limit" in load rating. If they are still "safe" then you can use them until they wear out.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Just to be clear, all 4 tires are the smaller size?
    Or are just the 2 older ones?
  8. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    I'm reading it as all 4 tires are now the smaller size.
  9. Mendel Leisk
    40,574
    Any competent tire shop would check the readily available database of specd tires. :mad:
    Same place each time? How many miles since the first mess up? And again, since replacement of the most recent pair?
    I'm thinking they take back the latest two, and get you into a set of four, the proper size.
    The first place in particular should be reported, that's unprofessional.
  10. The Electric Me
    9,083
    5,800
    That's how I'm reading it as well.
    But there are a few posts above that seem to suggest some people think it's 2 smaller and 2 larger, so I just wanted to clear it up.
