Wth is this random hose?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by raccoons, Sep 18, 2018.
  1. raccoons
    raccoons New Member
    los angeles
    hey everyone,
    i was driving when my engine started smoking so i pulled over and found out the coolant hose had broke. the hose was leaking coolant all over the engine and burning off causing smoke. i jimmied together a fix for the mean time but then i found that coolant was leaking from another random hose. im guessing this hose is the overflow but im not sure what it is supposed to be attached to.
    the hose in question is the one being held in the first photo. any info would be great
    49,507
    welcome!
    did you put those clamps on, or were they already there?
    how many miles on your car?
    are you the original owner?
    edthefox5 likes this.
  3. raccoons
    raccoons New Member
    los angeles
    yes i put those clamps on until I can get it to a mechanic. the car has about 130k miles and i am not the original owner.
  4. jerrymildred
    jerrymildred Senior Member
    11,513
    14,118
    Tampa, FL
    I can only see a short portion of it on my car and can't see either end. But if I had to guess, I'd say it must go between the radiator and the inverter coolant pump. The end you're holding is hidden by the hood latch on mine.
  5. Mendel Leisk
    38,735
    Took a look at ours: that black plastic junction is a Y shape, with two spigots on the right side. The disconnected hose looks to be the lower hose on right side.
    I've heard the screw-style clamps are tough on the spigots btw, create a "point load". The kosher clamps provide even pressure. Also, there's no clamp on the left side, as it comes from the factory. Ours has been fine thus.
  6. raccoons
    raccoons New Member
    los angeles
    that makes total sense. thank you
  7. bisco
    49,507
    i googled 'kosher clamps', they don't seem to be available in the states.:cool:
  8. Mendel Leisk
    38,735
  9. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Must have more Rabbi’s up there:whistle:?
    bisco and Mendel Leisk like this.
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    They are called "Corbin" clamps, although the original "Corbins" were made of wire. Dorman makes them. I've seen small ones available at Pep Boys. Larger ones for radiator hoses are available on Amazon.
    This type of clamp is preferred and used by most OEM applications, because it applies even pressure on hoses over plastic fittings. Common worm drive clamps impart a "stress riser" at the point under the screw area which could eventually destroy the fitting underneath. The worm drive screw clamp should not be used to replace OEM Corbin type constant pressure spring clamps. The spring clamps should be replaced with the same type for long plastic fitting life. Should the hose in the clamping area compress with age, spring pressure will maintain pressure and the seal.
    When I installed my OCC, I used Corbin type clamps. that I got form Pep Boys. occ installed Prius V 001.jpg
  11. Mendel Leisk
    38,735
    @Georgina Rudkus thanks for the info. I ordered this:
    OD of the 3/8" fuel lines I'm using is 5/8" (aka 16mm). Only thing: it is a royal pain to pry the hose off hose barb fittings; might be simpler to just buy some more hose. My lines were both slightly short anyway.
    Robert Holt and Georgina Rudkus like this.
  12. bisco
    49,507
    for the briss?:cool:
    Mendel Leisk and Raytheeagle like this.
  13. Mendel Leisk
    38,735
  14. raccoons
    raccoons New Member
    los angeles
    update: so i got a new Y shaped junction that mendel pointed out and hooked it up to my car. when i was driving today the SAME thing happened, suddenly a ton of smoke, so i pulled over to check out the car. the y shaped junction had melted at the same place it had before (on the lower hose). I'm not sure what would be causing this. my temperature gauge only came on at the start of my drive and did not come back on, even when it was smoking. also it looks like the hose exploded because there is white goop all under the hood.
    does anyone have any ideas what could be causing this??
  15. Mendel Leisk
    38,735
    Was that Y-connector missing when you got the vehicle? Something fishy here.
  16. bisco
    49,507
    maybe you need new hoses
  17. bisco
    49,507
    could a blown head gasket or clogged egr cause excess pressure?
    edthefox5 and Mendel Leisk like this.
  18. raccoons
    raccoons New Member
    los angeles
    thank you both for replying. i took E-lane (my prius) to the mechanic and he thinks there may be problem with the head gasket which is causing the hose to blow off since that is the weakest point in the system. hoping it doesnt end up being a $1.5k fix :-/
  19. bisco
    49,507
    sorry to hear it. this is a big problem with gen 3, and 2010's especially, since they have the most miles.
    i hope the mech is wrong!
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Bisco all up in there
