XM Antenna installation pictures
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Raider, Sep 22, 2007.
  1. Raider
    Raider New Member
    103
    Here is my Sony DRN-XM01 antenna installed on roof above driver door. Wiring was placed in one of the two channels in the plastic moulding. Moulding has metal clasps on leading and trailing edges, on the body. Between the ends, the mounding is held in place by the tapered sides of the channel.
    [attachmentid=11620]
    Here is the hatch opening showing the two-lead antenna routing under the hatch panel. The wiring is then run through the left most rubber boot, with the rear washer hose, behind the headliner, then down the side of the car.
    [attachmentid=11621]
    Here is a close up of the wire leaving the plastic moulding channel and the drip loop. Using a drip loop should prevent fluids from following the path of the wiring, and into the car. If necessary, I left enough wiring to extend drip loop further down past the top edge of the weather stripping.
    [attachmentid=11622]
    Wiring runs along driver side and up behind the dash to the receiver.
  2. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    What receiver are you using? The Antenna design is REALLY old.
  3. Raider
    Raider New Member
    103
    Sony DRN-XM01C Satellite Radio Receiver
    Yes, it is a old radio/antenna. I have about FIVE NIB receivers and EIGHT home/car kits so I will be using these for a while. I got these really cheap a few years ago when they were discontinued.
    Here is a picture of the first generation with a real sharkfin antenna. I have the second generation that comes with a smaller antenna, 20 presets and slimmer remote control.
    I have the receiver in the pocket below the radio controls.
    [attachmentid=11663]
