XM install PDF 58 pages and pics
Discussion in 'Gen 2 Prius Audio and Electronics' started by problemchild, Apr 12, 2008.
  1. problemchild
    problemchild New Member
    429
    36
  2. problemchild
    429
    36
  3. exbauer
    exbauer Active Member
    1,185
    100
    Washington
    glad you were able to do it. i will attempt to do this this weekend or the next. can't wait to have xm back in the car.
  4. problemchild
    429
    36
    Couple of tips........
    Pull the vents from the top first.
    The wire plugs have little push clips on top or bottom I pushed with ink pen.
    Lay the bolts in order of removal.
    Lay the parts in order of removal.
    Take your time and dont force anything.
    The screen is screwed on and clipped. Give it a tug to remove.
    I used a 10mm socket 1/4 inch drive with extender and phillips.
    My wife helped me hold things. I have a great wife. :)
  5. exbauer
    1,185
    100
    Washington
    Thanks for the tips. I am trying to figure out where the brackets go. I don't see them used in the PDF. Did you use yours and where do they go?
  6. problemchild
    429
    36
    You could drill holes and mount it under the rear pass seat in that little cubby hole. I just laid mine in the left cargo hold for now.
  7. exbauer
    1,185
    100
    Washington
    problemchild, i pmed you with more questions.
  8. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
  9. problemchild
    429
    36
    I bought it here in the PC store. Best price around.
  10. problemchild
    429
    36
    Bump for those who might need this.
  11. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    I just installed my XM radio tonight, i used the factory Toyota instructions which are much easier. If anyone that lives in the San Luis Obispo area wants to install one in their prius and doesnt feel comfortable doing it, let me know.
  12. TheDrGene
    TheDrGene Beard and Sandals Group
    Lompoc CA
    Attached to this are the factory Toyota installation instructions for 2006. (There is only one difference with the 2008) . They are much more simple than the 58 page directions with a lot, lot less dash disassembly.
    The only suggestion/modification I would provide is to place the antenna on the dash over by the driver's side of the car. (Being careful to not cover the sensor) That way the antenna is less likely to have interruption by roadside trees and buildings. There is plenty of antenna wire for placement.
    The one difference in the directions is that the 2008 has the side curtain airbags so removing the A pillar is not an option. The solution is to carefully separate the the dark plastic of the dash away from the A pillar and press the antenna wire into the gap. (I used a popsicle stick). It is easy to do without undo strain on the wire or the plastic.
    The brackets are for securely mounting the XM tuner under the right side of the rear passenger seat. The installation took an hour and a half being careful.
  13. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    I had horrible reception with it on the dash, so I relocated my antenna to the rear of the car where they tell you to put the sirius antenna.
  14. problemchild
    429
    36
    Because the antenna needs a ground plain made of metal. Stick it on the roof and get full signal.
  15. problemchild
    429
    36
    Try pulling the plugs out without removing the screen.
  16. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    I used the provided metal plate that they want you to mount the antenna on, and the reception was just horrible. Like I said, moved it to the roof of the car not it is great.
  17. TheDrGene
    Lompoc CA
    When I installed the antenna on the right side of the dash as per the instructions the reception was indeed horrible. I then moved the antenna to the left side of the dash and the reception is now great. There are almost no drop-outs except when we are under a forest of trees.
    I like the "on the dash" position to limit any chance for moisture to enter the rear hatch area by wicking along the cable.
    There is plenty of cable to move the antenna over to the left side. I was able to lift the base ground plate without too much difficulty.
  18. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    I have mine running through one of the factory grommets, there is no way water is going to get in, I couldn't stand the way they wanted you to run the cable for the sirius radio. Just lay the wire over the gasket???
