XXR WHEELS
Discussion in 'Prius c Accessories and Modifications' started by blueduce, Aug 13, 2012.
  1. blueduce
    blueduce Junior Member
    46
    I JUST ORDERED 1 WHEEL TO SEE IF IT WILL BE COMPATIBLE WITH MY C
    XXR 518 Featherweight Champ Wheel 15X5.5 +40 4x100 THEY COME IN 3 OR 4 COLORS
    I WILL POST WITH RESULTS ABOUT TPMS SENSORS FITMENT THANKS BLUEDUCE
  2. blueduce
    46
    Angel Natal likes this.
  3. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Those wheels will fit fine, order the rest of them. You'll need hub rings though, 73mm to 54.1mm. Chances are the stock lug nuts won't fit either; you'll need a tuner lug nut.
    The Prius c has almost no requirements regarding brake caliper clearance, certainly none in the rear due to the drum. The et40 offset is stock and fits fine with only a 0.5" width change. I posted some info in my "Hello" thread.
    It'll be interesting to see how the 4x100 bolt pattern looks with this wheel design. Keep us posted when you get them mounted.
  4. Jonathan F/2
    Jonathan F/2 Junior Member
    51
    SoCal
    Those look nice!
  5. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    Any update on this? I've been trying to find a picture of the 4-lug version with no luck.
  6. blueduce
    46
    picture of wheel the gold has a conflict with the nearby chrome otherwise nice wheel they told me 8 weeks to get other colors sending wheel back
  7. ianblake
    ianblake Junior Member
    53
    PR
    i like gold
  8. strongbad
    strongbad Member
    170
    47
    Driggs, ID
    Thanks for the pic of the 4X100 wheel. Sadly, it's awful. It's a 5-lug design and there's no way to make it a 4x100 without making an amateurish bodge of it. I'll look elsewhere. Thanks again for the pic.
  9. phenoyz
    phenoyz Member
    108
    nevada
    PIMP !!!!
  10. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Here are the XXR 518's Black with Machined Face on my C
    15 x 5.5
    4x100
    +40 offset
  11. blueduce
    46
    I went a different direction chrome wins looks good though
  12. Justgreat
    Justgreat Junior Member
    Greensburg PA
    Those look great! Mind if I ask where you got them?
  13. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I got the wheels from this site
    518 - OnlineTires.com
