Yakima Rack for 2013 v
Discussion in 'Prius v Accessories and Modifications' started by Diver Allen, May 27, 2013.
  1. Diver Allen
    Diver Allen Member
    66
    27
    Cincinnati, OH
    2013 Prius v wagon
    Yakima's website says to use the Q Towers for 2012 Prius v, but that they do not have a recommended solution for the 2013 Prius v. I believe this means that they haven't checked it out yet and not necessarily that they checked the Q Towers and they don't work.
    So my question is - have any you tried this combination yet? I've got other components of the Yakima system and would like to be able to just get the Q Tower pieces if that is all that I need.l
    A second question is - do you know if the short antenna toward the rear of the roof is easily removed or not?
    Thanks.
    Regards,
    Allen Miller
  2. Jzerocsk
    Jzerocsk Member
    108
    31
    You can unscrew the antenna.
    Not sure about the Q Towers, though...I did not thing there was any change at all between 2012 and 2013 but I got the same thing from a Yakima salesman last week. He felt the same as you - that it may well use the same Q-clips, but they have not yet been tested.
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    I just checked the Thule site configurator and the part number for the attachment to the car seems the same. I would assume the same for Yakima....
