Yay, going to have to be towed to the stealership.
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Jun 14, 2025 at 8:21 PM.
  1. Prius92
    Prius92 Active Member
    483
    109
    Iowa
    The engineer who hid the driver's side axle behind the subframe and put ribs of aluminum around the axle so you can't use a normal puller, I hope gets forever wet socks.
    I managed to somehow mess up, what I think is the output shaft seal? Trying to use a crowbar to get it out.
    So now I'm going to have to give Toyota probably $300 of my hard earned money to put a new axle in (I have the new axle).
  2. Carall
    Carall Member
    228
    53
    Harrisonburg, VA
    All you need is a lift and a long thick crowbar. Any mechanical shop would do it. Why do you need a dealer?
  3. Hayslayer
    Hayslayer Member
    182
    98
    This thread helped me a lot when I was dealing with a stuck axle. You actually use the axle itself as a slide hammer. Works great, especially when you plan to replace the axle anyway.
    CV axle stuck in transmission? | PriusChat
