Yellow brake warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Old fat fireman, Aug 27, 2023.
  1. Old fat fireman
    Old fat fireman New Member
    Connecticut
    Help needed on issue, it has alot. 178k and running well. Yellow brake warning light is the issue currently
    #1 Old fat fireman, Aug 27, 2023
    49,415
    that's alot of codes, is the 12 volt healthy?
    49,415
    49,415
    can also be connector corrosion not allowing proper voltage to ecu's
