YELLOW CAR WITH EXCLAMATION POINT
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Uberfast, Jul 28, 2023.
  1. Uberfast
    Uberfast Junior Member
    76
    Oakland , ca
    2014 Prius v wagon
    2014 Prius v. 278000miles
    See image, below highlighted word vehicle.
    I can pull any codes. The light appears every morning. I just clear the code with my scanner.
    Do anyone know or has had this ?
    Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,718
    Texas Hill Country
    Hybrid code. Often temperature. If your scanner does not see the codes you need a better scanner. Read codes or take in.
    From the owners manual:
    #2 rjparker, Jul 28, 2023
  3. Uberfast
    76
    Oakland , ca
    2014 Prius v wagon
    Ok JP.
    Thanks for the quick response.
  4. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Inverter or Traction Battery............
    Inverter covered under extended warranty.
  5. ChapmanF
    15,622
    Or any of the around 200 other things that light that light. That's why the car has trouble codes that can be read.
    If the codes include the ones mentioned in the inverter warranty extension, then yes, check the coverage there. I think that's the one that was recently extended again to 20 years. But did it say unlimited miles? I forget. The 278,000 could be an issue.
  6. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Yes but usually the top 2... Miles don't matter on the inverter repair.
