Yellow cast to 2023 side & rear window?
Discussion in 'Gen 5 Prius Main Forum' started by CornerCarver, Sep 23, 2023.
  1. CornerCarver
    CornerCarver Junior Member
    Bend, OR
    2023 Prius Prime
    XSE
    I test drove a 2023 Prime XSE today and noticed that all of the side and rear windows had a slightly yellow cast to them, the windshield did not have it. It was a cloudy day, no direct sunlight. Has anyone else noticed that?
    If/when I buy a prime (have a deposit on one) I plan to have all of the side and rear windows tinted, but still that could effect the way the windows look even with the tint on them.
    BTW, I looked at a couple of other new Toyotas (other models) on the lot and couldn't see the same tint.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Those windows likely already HAVE a tint built into the glass but a "ceramic" coating that is better
    than anything else you can add.
    Unless maybe you are going for the "bad assed gangster" look. :eek:
    :ROFLMAO:
