Yellow light flashing and beeping
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Apr 6, 2017.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    In the past few weeks, the yellow light has been coming on from time to time (maybe twice in a 12-mile trip) and I have heard beeping. Strangely enough, this has been happening in dry weather. I don't detect any change in what the car is doing, but it's odd to have that light flashing and hearing the beep. Is this a sign my tires need to be replaced, or of something else -- or of nothing at all?
  2. ChapmanF
    17,345
    It would help some if you could describe which yellow light; there are more than one.
    It would help a lot to pull the diagnostic codes from the car using a suitable reader.
    Your thinking seems to be running along the lines of stability or traction control. The computer that does that has a rudimentary way to blink out trouble codes when triggered by a short piece of wire. That will only show actual trouble codes, as in, if it really thinks there is a problem.
    If the control has just been activating under certain driving conditions and doing what it's supposed to, it won't log trouble codes. On the other hand, it does remember the last several (four, maybe?) times it activated, what was happening at the time, the power, all four wheel speeds, acceleration and cornering g forces, etc. That can be read out any time using Techstream. That might give you something to go on.
    -Chap
  3. southjerseycraig
    438
    107
    Cherry Hill, NJ
    I am sorry not to have been clearer. I meant the yellow light on the left side of the instrument panel with the picture of the car slipping around the road.
    51,154
    how are your tyres pressure? are all 4 tyres the same model?
  5. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Are you pulling fast u-turns, or accelerating rapidly through a sharp turn when the error light flashes? If yes, then it's the traction control detecting differences between the inside and outside wheel speed.
  6. southjerseycraig
    438
    107
    Cherry Hill, NJ
    The pressures have been OK, but it's true that the four tires are not the same model. I had a flat several thousand miles ago, and the tire dealer insisted I only needed one tire and the model is different from the rest. . But the problem didn't start then.
  7. southjerseycraig
    438
    107
    Cherry Hill, NJ
    Thanks, but I'm doing neither of those things. I'm engaged in fairly normal driving. I'm a scaredy-cat and don't do anything exotic.
  8. bisco
    51,154
    have you had the tires rotated recently?
  9. southjerseycraig
    438
    107
    Cherry Hill, NJ
    About 3000 miles ago, assuming the Toyota dealer did what it was supposed to. It sounds like you also think there is a tire issue here.
  10. bisco
    51,154
    just guessing. no idea really, except i've read you should match tires on the axle, it can affect the speed sensor. i thought maybe moving the odd tire to the front might have caused a problem, but maybe not after 3,000 miles.
  11. bisco
    51,154
    what speeds is it happening at?
  12. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
  13. ChapmanF
    17,345
    That's the exact kind of information that can be retrieved from the traction computer.
    -Chap
  14. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Craig, I don't know if the light has stored a code that a ScanGauge will read but I'm close enough to take a look at the car. Send me a PM if you're interested.
