Yellow warning light flashes very briefly on hard turns
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobzchemist, Jan 18, 2017.
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    No codes are being thrown, and the light flashes so quickly I can barely see it. Anyone know what's going on?
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    It could be the VSC.
    WilDavis likes this.
  3. Mendel Leisk
    40,586
    Check your oil?
  4. bobzchemist
    507
    342
    So the light goes on when the VSC engages? What a great time to distract me from driving.
  5. bobzchemist
    507
    342
    Oil is full up.
  6. JC91006
    16,674
    8,519
    It's telling you not to corner so hard
  7. Mendel Leisk
    40,586
    Yellow triangle?
  8. bobzchemist
    507
    342
    I think so, but I'm not really sure. It's just a very brief flash of yellow, so fast that by the time I drop my gaze to the display, it's gone.
    I'm fine if it's just the VSC yelling at me, but more concerned if it's indicating a clog somewhere, or something else wrong..
  9. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Wheel speed sensors have been reported to activate VSC on fast u turns due to speed difference between the inner and outer wheels. Perhaps this is the case here?
  10. bobzchemist
    507
    342
    xliderider, I hope that's the case, but how could I know for sure?
    Finding out that there's a yellow warning light for VSC is actually reassuring, though.
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    I've noticed that on my 2009 Gen II the VSC NagLight will occasionally blink when I'm driving a bit on the edge for the circumstances, i.e. hitting a "hump-back bridge" too fast, so the wheels are unweighted and might confuse the system by slipping or spinning. I've noticed the same happening if I drive on slippery, wet surfaces (i.e. painted lines, irons plates, ice) and accelerate too quickly.
    Edit: It happens so quickly that I remember the first few times it happened, I didn't have time to register what it was, but after seeing it a few times, I was able to locate the position of the flashing light, and sure enough, there it was (…bottom row, towards the left (…I think!))
    #11 WilDavis, Jan 18, 2017
  12. Mendel Leisk
    40,586
    ^ Just for reference. I'm searching the manual for an explanation of triangle with exclamation, and assuming it's yellow. Can't find anything though. Or maybe the skid symbol directly above? It'd be nice if this image was used as a visual directory in the manual. As-is the symbol explanations are scattered all over the manual, in different sections.
  13. bobzchemist
    507
    342
    Having had fun slipping all over the ice last week, I know it's not the slip indicator - that is a darker yellow than what I'm seeing. It's in the same area of the display, though.
  14. Mendel Leisk
    40,586
    Raytheeagle likes this.
  15. bobzchemist
    507
    342
    Thanks!
  16. bisco
    51,155
    are the tires all the same, with correct pressures?
  17. Former Member 68813
    3,524
    983
    US
    even if oil is indeed full, too hard turns could conceivably produce momentary oil starvation. you have to record the dash to see for sure.
    BTW, is it just a light or a triangle?
  18. Mendel Leisk
    40,586
    If you're regularly checking the oil, used to the idiosyncrasies of the Prius dipstick, the oil is full, case closed, lol. If you just started checking it, just to put this to bed:
    With the car on level ground, remove the dipstick, wipe it, and just lay it across the engine, somewhere flat. Wait at least 10 minutes. Then reinsert, pull out and check level.
    Reason being, the dipstick guide tube on the Prius seems to hang-up oil when the dipstick is first withdrawn, making for a real mess when trying to read it. Ten minutes grace gives the oil in the guide tube time to drain down.
  19. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Have you checked the brake fluid level? I had a leak on my previous car and initially only got warnings when going around corners. I'd expect one of the brake warning lights to illuminate too but not sure which on the US versions, and it may be less obvious than the big yellow triangle.
  20. KJX
    KJX New Member
    Vancouver
    Be super nice if that useful page showed the light symbols in color. Helpful but ..could be more helpfuller ;)
