Yellowed and scratched headlights 2004 HID
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by labumm, Jan 25, 2013.
  1. labumm
    labumm Junior Member
    62
    After 9 years and 111k my headlights are yellowed and scratched. Can I just replace the plasic part? Doing so will give me more light on the road.
    The HIDs are working great and I have had no problems whatsoever. So I don't want to risk messing up the HIDs.
    Poking around here I found the suggestion of polishing the the plastic lens. I see how that will remove the scratches and surface yellowing. But I am afraid that will leave the surface of the plastic softer--I assume there is a hard coating on the plasitc.
    I plan to keep this car for another 5 years. If I replace them now, I'll get 5 years of use out of them. What are my options?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  3. labumm
    62
    Thanks for the link. Sounds like a buffing wheel and a series of grits and polish will do the trick. The choice of which will depend on the type of plastic.
    Are these headlight assemblies polycarbonate or something else?
    I have no idea what the protective coating would be in Sylvania's kit. Any ideas?
  4. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    I know it is not designed for it, but never-dull has done a fine job for me. Its basically treated cotton and it removes the yellowing from my lenses without scratching. Afterwards I simply apply automotive paste wax. The lenses on my '06 Prius and '07 Tundra are clear. I have used the 3m on a friends car and it did a good job on her VW.
  5. Photau
    Photau Junior Member
    46
    Mastic Beach Village
    I used the the kit from turtle wax on my old Echo, worked nicely.
  6. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    I used the Sylvania kit on my 05 and got very good results. Took about an hour as it was our first time. Just followed the instructions.
  7. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    I had my local Toyota Dealership do Ema's eyeballs just a few months ago and the result has been fantastic. I actually had to drive around with my high beams on to have decent visibility before and never got flashed by cars for my lights being to bright. Now I routinely get flashed when just the low beams are on.
    I choose the Stealership because it doubled the length of the warranty on the service over doing it yourself. I also figured someone that does it all the time may have more skill then myslef doing it a single time. It is a pretty in depth process and the best curing for the coating is direct sunlight so it needs to be done on a bright sunny day. I think Toyota's is Service Rite Lens Restoration or something like that?
    Hope this helps,
    Chris
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Meguiars PlastX is a great tool to use to clean and maintain those yellow/scratched up headlights. It works best if you keep them clean to begin with. However you need to get one of the restoration kits to clean them up as other's have mentioned, then maintain them with the PlastX.
    Ron
  9. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Clear coat.
    You can use a wax as a temporary solution, or a laminate as an easy long-term solution.
    Best fix would be to polish, clear coat and wet sand it yourself.
  10. richard schumacher
    7,664
    1,047
    United States
    It sounds like they messed up the aim when they did the job. (I assume that the lenses are now clear and not hazed.)
  11. CBarr31
    436
    225
    Charlotte, NC
    Huh? ... You must have misunderstood. The low beams are so bright now that the headlights have been restored some, not all, people think I have my high beams on when I don't. This was typical when Ema was new in 2006 some 300K ago, lol. When headlights are restored only the lens are cleaned, coated, buffed, etc... nothing is done with the aim.
    Chris
