Yellowstone NP charging
Discussion in 'Prime Plug-in Charging' started by Marine Ray, Jan 11, 2020.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    Will be visiting Yellowstone NP this Summer and staying at Old Faithful Cabins. Plugshare shows two plug ins at that location. Does "non networked" mean free? Also, the Clipper Creek chargers are rated at 32 Amps. Is it safe to plug in? I suspect OK, but will only charge at 16 Amps max. Capture10.JPG
  2. Marine Ray
    1,139
    947
    Sparks, NV
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes, the ‘charger’ advertises what it can do, but the car decides what it will do. Any j-1772 is fine.
    Marine Ray likes this.
  4. Tideland Prius
    16,621
    Yup. As long as it’s J1772, you’re fine.
    Non-networked just means you can’t see its status - whether it’s online/offline or available/in-use.
    Prime Alex and Marine Ray like this.
  5. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    Yes you’ll be fine. The advertised 32A means the maximum a car can draw from the charger. Your car ultimately decides how much it wants to draw and the charger will only deliver the amps requested by the car.
    iPhone ?
