Yelp! I pulled out my bumper :(
Discussion in 'Gen 2 Prius Main Forum' started by Prius2006GuitarGuy, Sep 26, 2024.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    40
    Sweden
    Accidently got it caught in a pipe that was sticking out of the ground while reverse parking, need some help in putting it back in (that's what she said :p ), here are the pics:
    461024943_1000888178392904_1935023311610833231_n.jpg 459724736_1578586553035006_878139591336335985_n.jpg
    How do I fix this? I tried pushing it back in place but that's a no go :(
  2. pasadena_commut
    pasadena_commut Senior Member
    1,668
    503
    Southern California
    The bumper needs to be lifted up and shoved in so that the visible loops go over the sort of hook things that hold it in place.
    However...
    Pull the black fender liner back a little next to and below the back upper edge of the bumper cover and you should see a bolt head, with the bolt pointing upwards. That is ultimately what keeps the bumper cover from popping out again. It is likely that your accident tore something there, and it looks like the place on the bumper cover where that vertical bolt is attached is missing. That fragment is probably still in there, still held by that bolt. There is also a bolt on the bottom rear corner, which comes up from underneath the car.
    Watch this video, 4:44 for the top bolt, 2:59 for the bottom bolt:
    Note, if you start messing with the fender liner and bumper cover you will break an assortment of fasteners. That old plastic becomes very fragile with age.
    MAX2 likes this.
