Yes, there is smart key on LE and SE trims but only for the driver's door and ignition
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Jan 3, 2023.
  1. Gokhan
    Gokhan Senior Member
    4,194
    1,690
    Paramount CA
    There has been a lot of misinformation on this, even misinformation coming from Toyota/Toyota dealers!
    I skipped through the 2023 Prius manual:
    • LE and SE trims do have a smart key.
    • However, there are antennas only on the driver's door and ignition—not on the passenger's door and back door.
    See page 131 for details.
    https://assets.sia.toyota.com/publications/en/om-s/OM47E41U/pdf/OM47E41U.pdf
    #1 Gokhan, Jan 3, 2023
    48,862
    nice find! finally put that one to bed
  3. FuelMiser
    FuelMiser Senior Member
    1,263
    858
    Monument, CO
    Back in the day, we called it 1-Door SKS vs. 3-Door SKS (Smart Key System). It's the only scenario that makes sense. They are not going to produce two different key/fob designs for different trims of the same car!
    CR94 likes this.
  4. Salamander_King
    Salamander_King Senior Member
    10,958
    8,836
    New England
    I don't know about the current Gen4 regular Prius lineup, but for the current generation PP, LE has 1-Door SKS and XLE and Limited have 3-Door SKS. So, that assignment is no different for the upcoming Gen5 Prius lineup then.
    Tideland Prius likes this.
  5. Tideland Prius
    16,016
    Ok so same as before then? (Gen 3/4)
    CR94 likes this.
  6. zyn
    zyn New Member
    DMV
    It can be seen in the configurator that the drivers door has the markings on the handle that indicate keyless entry. I'd normally think configurators aren't 100% accurate but with the Prius I've seen everything accurate as advertised and more with immaculate detail.
    This will be my first new car and I've only ever touched a push button start once in my life (girlfriend's Accord), so I'd say my standards are pretty low, but I'm excited for what the LE has to offer and I think it's more than anyone thinks as there have been several noticeable typos in Toyota's writing about it.
  7. Trollbait
    11,213
    Toyota does so with other models. It just seemed unlikely with the Prius considering how long the base trims have had 1 door SKS.
  8. Tideland Prius
    16,016
    Yeah. Doesn’t the base RAV4 Hybrid make do with a key?
  9. farmecologist
    farmecologist Senior Member
    1,945
    1,785
    Southern MN
    Also looks like all models have push button start as well ( page 180 ). (y)
  10. priusmouse
    priusmouse Member
    239
    Long Island, NY
    2023 Prius
    Umm, there are SE trims?
  11. Trollbait
    11,213
    In markets that get the 1.8L engine, the LE's could get that, and the SE the 2L. Also once saw Canada get SE while the US got LE for a car model.
  12. Hammersmith
    Hammersmith Senior Member
    1,131
    1,118
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Prius HEV has the LE trim, Prius Prime PHEV has the SE trim. It was the OP's way of saying both base trims will have 1-door SKS. The manual does not refer to trim names at all.
    Gokhan likes this.
  13. Gokhan
    4,194
    1,690
    Paramount CA
    Yes, the base trim for Prius is called LE whereas the base trim for Prius Prime is called SE because Prius Prime has more horsepower than Prius.
