Yes we are towing a Motorcycle
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Gulfstreamaqua, Dec 20, 2015.
  1. Gulfstreamaqua
    Gulfstreamaqua Junior Member
    Socal
    I know there is much discussion and opinion regarding this topic.
    FYI this solution works great. NO issues at all (does not bottom out) and the car handles fine.
    Torkliift (2")- bolted and welded with MX Hauler
    m.wynn, minnyprius and bisco like this.
  2. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    …just curious as to how it might affect the fuel consumption (…of the Prius, that is!) o_O
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    That's not towing, that's hauling! :)
    I also have a hitch mount for my CMax. Trip to the recycler. Adds so much utility. (y)
    Mendel Leisk and PLSPUSH like this.
    49,490
    welcome! did you have to change the rear springs? how much does it weigh?
  5. Gulfstreamaqua
    Socal
    We have not calculated but I assure you it is far less than any truck :)
    did not change springs (could always add spring stiffeners if this becomes a regular occurrence).
    Bike= 219lbs and MX Hauler weight 57lbs. (friend of son has a small 100cc bike-= 160lbs that we have hauled and had him carry the bigger 450 Yamaha) Aware there is a 200lb tongue weight guideline so we welded the tow hitch in addition to the bolts that came with the kit.
  6. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
  7. Gulfstreamaqua
    Socal
    That is great to know- very helpful.
  8. flyerjonathan
    flyerjonathan Junior Member
    22
    I get about 33 mpgs towing this. :)
    Was just thinking you may want to add on some lights to the set up, wouldn't want somebody taking you out in the dark.
    m.wynn likes this.
  9. LamboGuy
    LamboGuy Junior Member
    53
    Silly question but what's the maximum towing weight?
    iPhone ?
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    According to Toyota? Zero pounds. ;)
  11. LamboGuy
    53
    To your knowledge what's the maximum anyone ever towed using a prius?
    I was asking since I'm thinking of towing my Lambo (~4,000 lbs with the trailer) to racing events that are further away - I'm also thinking of buying a formula Ford (~2,000 lbs with the trailer). Are there any laws that prohibit you of what you can tow?
  12. Gulfstreamaqua
    Socal
    [/QUOTE]
    I ordered and installed and used the Sumo Spring inserts= EXCELLENT - highly recommend.
    Thanks for the tip.
  13. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Yes. In my experience, states (and it is a state-by-state thing) use the manufacturer's Max Towing Capacity rating as the legal limit. Since Toyota specifies no towing capacity, I presume it's technically not legal to tow with one. Any hitch you buy will be a Class 1, and have a max weight of no more than 2000 pounds. However, the rating of the hitch is irrelevant from a legal standpoint: the car still has no Max Towing Capacity rating.
    Just FYI: Class 2 goes to a max of 3500 pounds, and requires electric trailer brakes. This is mid-size SUV/pickup and full-size/RWD car territory.
    To tow your Lambo to track days, you're solidly into Class 3 territory. That's going to require a full-size SUV or half ton pickup.
    Having said all that... Would I feel comfortable using my Prius to tow my utility trailer across town for a Home Depot or dump run? Yes - at 35 - 45mph.
    Would I feel comfortable using my Prius to tow a 2000 pound trailer on the interstate? Absolutely not.
    LamboGuy likes this.
  14. LamboGuy
    53
    That's good info, thank you for your answer!
  15. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I dig it! I have been considering buying a new Honda grom, Kawasaki ninja 600R, or Triumph speed triple. However, my truck is sitting on my family's ranch 4 hours away from me. This just confirmed I can rent a motorcycle trailer and tow a new bike home myself.
  16. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I would love to see a link to your flying machine because that looks awesome!
    Great knowledge here.
    I would liek to add that a lot of Prius towers are using the very nice Torklift EcoHitch: Torklift Central | 2010-2015 Toyota Prius & Prius Plugin EcoHitch - Toyota - Find Your EcoHitch - RVing and Towing
    It allows us to use a "Class 3" 2" receiver with the caveat that we only tow up to 2000lbs. Also one could purchase a aluminum trailer that's almost half the weight of a steel trailer that give you more payload capacity since the trailer is so much lighter.
    And like tvpierce suggests, slow down when towing, keep the car in power mode if you have that option so your leaning on the engine more than the electrical system, etc...
    My 400lb empty 6'x12' utility trailer has provided me with so many options to move material with my Prius that I won't need a truck until I do some sort RV traveling in the future.
    Lunnara and m.wynn like this.
  17. flyerjonathan
    22
    Here you go...
    frodoz737 likes this.
  18. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    Thanks for sharing the video. I just realized that I forgot to respond after viewing it.
    Looks like a very liberating experience.
  19. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    good lord, it's a giant motorized kite! fetch me the shootin' iron there Jim-Bob!
  20. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    will UHaul let you rent a trailer if you have proper lights and hitch?
