Yet another fuel economy thread
Discussion in 'Gen 4 Prius Fuel Economy' started by sjr14221, Sep 30, 2017.
  1. sjr14221
    sjr14221 Member
    115
    28
    WNY
    Four Touring
    Mine is a little different, i expect...
    I bought my 2016 4 touring on October 1st, last year. Mileage started in the upper 40s and increased to mid 50s. Then came Buffalo, N.Y. winter. I had 3 months averaging 44 mpg. Spring came and mileage picked up; however, June 1 i was front ended by a pick-up truck. Car was in the collision shop for over a month while they hunted down oem parts. Now I've been getting 55+ mpg.
    Over all i have only managed to average 49 mpg in 27,000 miles. Caveat: I've had the car on blizzak snow tires the entire time since last November (don't judge, please ). I will probably just manage to get an overall mpg of 50 - 52 before winter strikes again.
    My first prius 2004 package 9 averaged over 55 mpg most of the time. I have had a couple 600 gallon tanks. I only used the vehicle's mileage calculator in all 3 of my priuses (second was a 2009).
    I know i have the larger tires, but i was REALLY expecting to see a difference in fuel efficiency from the 2004 to the 2016. I have the same commute. Interestingly, the 2004 epa rating was 54, i believe, until someone decided it was flawed and lowered it to 48. But i did get in the 50s. Now, with this new prius, it seems i am doomed to average in the upper 40s for the several years.
    I am disappointed to say the least. Wish i had waited for the prime - no clue about the federal and state tax credits - probably because i hadn't kept up with prius chat for a few years. The only thing this prius had going for it (compared to the prime) was the seaglass pearl.
  2. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    What tires did you have on your previous Prius?
    I had a 50.1 mpg lifetime average on my Gen2 after 67k miles.
    When I renewed the tires at ~35k miles the mpg dropped about 10% and took a few thousand miles to recover.
    My current gen4 is at 56.1mpg after 6 months and 6000 miles.
    kevin
  3. Mendel Leisk
    38,751
    Maybe the Blizzaks? Seems like the gen 4's are returning some disgustingly good mpg, on the whole. But hang on: you're currently getting 55 mpg? That's good, no?
    Also, I'm not clear, are you calculating, or is this displayed.
    RCO likes this.
  4. sjr14221
    sjr14221 Member
    115
    28
    WNY
    Four Touring
    this is the display doing the calculations. I am pleased with my summer mpgs. Really disappointed with the winter numbers - which seem to weigh more than the summer numbers. Overall, it is likely that i won't hit more than 50 mpg taking all seasons into account.
  5. Mendel Leisk
    38,751
    Sounds like tough slogging winter conditions. Keep in mind too: the car monitors ambient temperatures, and changes warm up behavior accordingly. From reports here, in warm summer conditions, the car will occasionally start up and drive without a mandatory engine start up?
    You get used to that, then ambient temps drop, and the car reverts to more gen threeish behaviour. Couple that with Blizzaks, snow, bitter cold, defogging and so on.
    Maybe start calculating tanks and logging. A spreadsheet gives the most control, or just use Fuelly website.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    No not different at all.
    It mostly boils down to unrealistic expectations in almost ALL cases......where there is not an actual defect involved.
    The most important thing that I got from your post is:
    You NEED to completely FORGET about your "overall average".
    It is meaningless for anything practical.
    Reset that overall average and pay attention to your current situation......if you MUST.
    Don't worry; be happy. Really. :)
    RCO likes this.
  7. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I find it starts up if over 20 mph even if there is good charge in the battery. I sometimes forget to keep it below that when leaving work. Speed limit is 15 but most people ignore that.
  8. Mendel Leisk
    38,751
    Gen 3, you start the car, 10~15 seconds elapse, engine starts, regardless of ambient temp.
  9. Prodigyplace
    11,696
    11,318
    Central Virginia
    If I am careful, I can make it the 0.3 mile to the stoplight with no engine running. I then need go on a ramp to merge onto a 65 mph freeway, though. :eek:
  10. Mendel Leisk
    38,751
    I wouldn't chase EV too hard. It might be advantageous to purposely kick the throttle, wake up the engine. Especially to avoid cold engine acceleration at the freeway entrance.
    I do play tricks sometimes, to try to keep it in electric-only, but yeah, it's a balance.
    UltraJetRefill and Prodigyplace like this.
  11. Prodigyplace
    11,696
    11,318
    Central Virginia
    In colder weather the engine kicks in when the heater or defroster is on anyway. I do not think Trim Two has an electric heater.
  12. sjr14221
    sjr14221 Member
    115
    28
    WNY
    Four Touring
    I hear you. Anyone else would be thrilled to get that mileage from their vehicle. I guess i was most disappointed that there was no noticeable difference from my 2004 prius.
    RCO likes this.
  13. Mendel Leisk
    38,751
  14. Prodigyplace
    11,696
    11,318
    Central Virginia
    I only measured once and the dash was 10% optimistic.
  15. Mendel Leisk
    38,751
    One calc'd tank is the most vulnerable to the vagaries of fill technique. If you do two, three, four, it'll settle down to the fudge factor, which I'd say must have been imposed intentionally by Toyota. A consistent, positive bias, now who might have done that...
    Of interest: Wayne Gerdes (CleanMPG) had a pre-production model, and found the displayed mpg virtually matched calc'd. He disclosed that when he returned it to Toyota it was destined to be crushed. :cry:
    Prodigyplace likes this.
  16. bisco
    49,519
    my 2004 got 60 mpg, my 2012 gets 70. i'm expecting 80 in the gen 4. i would look at tyres, they make a uge difference.
    #16 bisco, Sep 30, 2017
  17. Prodigyplace
    11,696
    11,318
    Central Virginia
    I doubt the pre-production units used different size tires.
  18. Mendel Leisk
    38,751
    I'd think @bisco is referring to rolling resistance, not varying outside diameter? (n)
  19. bisco
    49,519
    i don't even know what 'pre production units' are. or i should say, what they have to do with the o/p.(n)
    RCO likes this.
  20. Mendel Leisk
    38,751
    I'm guilty of drifting, specifically the accuracy of displayed mpg, vs calculated. Wayne Gerde's 4th Gen was an early one, not finished product. I was postulating that one of the unfinished bits was that the optimistic mpg "spin" hadn't been applied yet, the car still reported mpg semi-accurately.
    But yeah, off-topic.
    Prodigyplace and bisco like this.
