yet another help me decide on a tire thread for an 06
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cwerdna, Mar 26, 2009.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    When it comes to tires, I'm almost a dummy on this subject. Is there a good FAQ or KB article on tires to get/avoid for the Prius?
    After 37K miles, front stock Integrities are pretty worn and I'll need two new tires soon. The local Goodyear refused to rotate my tires a few months ago saying it was a bad idea to put such worn tires on the back in wet weather. My rears aren't too bad shape and one Integrity is much newer than the rest because one had to be replaced after puncture by a screw at the very edge (unpatachable).
    My criteria are that they should be no worse than the stock Integrities in:
    - mileage (most important, I don't want to take a hit of a few mpg)
    - dry braking
    - wet braking
    - hydroplaning
    - wet and dry traction
    - road noise
    If they're a little worse in terms of treadwear or ride, that's ok. I don't care about snow performance as it doesn't snow here. Money isn't an issue but I'd rather they be under $150/each.
    I'm on the stock wheels so I'd prefer to stick w/the stock size (185/65R15). Suggestions?
    In http://priuschat.com/forums/care-ma...get-absolute-best-mpg-prius-4.html#post812221, ken1784 cited the Bridgestone Ecopia EP100 but the closest size for the EP100 that Tire Rack carries is 195/65R15. Are there any problems w/using that size w/the stock wheels? What about when combined w/the stock 185/65R15 on the other axles? Any problems when it comes to rotation time (e.g. mechanic giving me grief)?
    Should I just find a place that it 185/65R15 instead? Sizes and Specifications says they exist. (I have no loyalty to Tire Rack.)
    How about Bridgestone RE960AS tires? (at 185/65R15) Tirerack lists them as Ultra High Performance All-Season. I'm fine w/better handling and braking. I saw Patrick's post on them at http://priuschat.com/forums/prius-main-forum/45363-bridgestone-portenza-tires.html. Anyone have experience w/them?
    (When I had to get new rear tires for my 350Z, it was an easy choice based on everything I read, solely from a handling POV: Michelin PS2 or Goodyear Eagle F1 GS-D3.)
  2. richard schumacher
    7,663
    1,038
    United States
    Sorry, no FAQ pointer. You're doing pretty good if you get 37K from the Integrities. At that rate, and if you're happy with their performance otherwise, the cheapest solution is probably just two more Integrities. Otherwise people do recommend Nokians and Michelins highly.
    By The Way, you will get maximum life and safety from tires on a front wheel drive car by not rotating them. The front two will wear faster, so when they wear out move the rear two to the front and put a new pair at the rear. (If any of the tires wear asymmetrically or one wears much faster than its mate, that calls for an alignment or a suspension repair, not rotation.)
  3. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    1. The 195/65/15 size will fit, but it will throw off the speedometer more than necessary. The closest alternative size to the OEM 185/65/15 is 195/60/15.
    2. I think nyprius' http://priuschat.com/forums/prius-modifications/20573-tire-upgrade.html is the best PriusChat thread on tires. I'd read nyprius' initial post and as many of his and the other posts as you can stand.
    3. Goodyear Assurance TripleTreds are the highest rated passenger all season tire by Consumer Reports:
    [​IMG] Consumer Reports Ratings Passenger All Season Tires.doc
    By TireRack.com customers:
    Consumer Survey Results By Category
    And by TireRack.com's road tests:
    Comparing Our Top-Rated Passenger All-Season Tires
    4. I have had TripleTreds on 3 cars now. I like them a lot. All things considered (traction in all conditions, braking in all conditions, tread life, noise, ride comfort, rolling resistance), I don't think there's a better all around tire for the money. But the TripleTreds do not come in the OEM 185/65/15 size. If you want them you'll have to get them in the 195/60/15 size. Personally, I prefer the 195/60/15 size. Everything else being equal, the wider tread should provide better handling and braking, but there will likely be a slight drop (2 mpg) in gas mileage.
    5. If and when I need new tires for my Prius, I'll probably go for the Michelin X Radial, which is a "Club Tire", i.e., it's available only at clubs like Costco. It's Consumer Reports' second highest rated passenger all season tire, scoring only 1 point less than the TripleTred. It's rolling resistance is rated "Excellent" compared to the TripleTred's "Very Good", so you should get good mpgs from it. Also, it comes in the OEM 185/65/15 size.
    Good luck.
  4. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    I'm looking towards the Yokohama Touring-S in stock size or 195 60 15 because they were rated better than average for low rolling resistance by consumer reports.
  5. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Have a look at this tirerack test with actual Prius cars
    When Round and Black Becomes Lean and Green
    Ecopia seems to be the best option and they're highly thought off here. They are great for wet surfaces, only second to the A/S energy savers for mpg and not significantly inferior in dry conditions.
    That's what I would put on if I were you, but then again I followed Richard's advice a few years ago and inflated my integrities to 44psi. They still have tread left in them for at least another 9 months at which stage they will be ~52 months and 46,000 miles old.
  6. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    I have had good success with the Nokian WR G2 in 1856515, In mostly highway driving I got over 70k out of them, still with useable tread. No mileage hit and a definite traction upgrade over the (lack of) Integrities. Also has a 51psi max with most other tires at 44.
  7. n8vspud
    n8vspud Junior Member
    Meridian, ID
    Can't give specific feedback about tires, since we are on our fourth set from Les Schwab, but we found that if we go higher in price on tires (about $100 per tire) and also have them filled to about 5 points over the recommended fill (which is typically 32) and rotate them every time we change the oil, it seemed to slow down the wear and tear. It has seemed to help.. The other thing to ask too when you do look at new tires is if they give credit back if the tires wear out before the warrantied miles? I don't know about other tire stores, but Les Schwab does that and it does cut down on the cost, even though the Prius does go through tires pretty darn quickly.
    Hope that helps. Good luck!
  8. nu2prius
    nu2prius nu2prius
    27
    Missouri
    I second the Nokian WR G2's. I will be on my 2nd set, and 4th set overall of Nokian WR's, on various cars. Great tires, plus an increase of approximately 2-4mpg over stock, and various terrain.
  9. mrshred
    mrshred Junior Member
    New Jersey
    I put Goodyear Fuel Maxes on my 05 at 49K, now 78K and tread still looking good. If you buy them at Goodyear, free rotation for life is included, every 6K, which I take full advantage of. Noticably improved mileage from average 44 to 46-47. Seem a bit noisier than the old Integritys, though.
  10. Racerman15@comcast.net
    [email protected] Junior Member
    28
    San Francisco
    2020 Prius
    I put on Michelin Hydroedge. They are an 86T rating which is much higher than the orig. tires. from Costco w/free repair & balance.
    Initially the mileage dropped 2 mpg (was 51). @ 20k on the tires the mileage has come back up to the same as the original tires.
    The Michelins are very quiet and do not have the tendency to wander on grooved concrete highways likt the original tires did. Plus they are great on wet roads.
  11. nthach
    nthach New Member
    174
    I've just ordered a set of Michelin Primacy MXV4s for the parent's Prius. Costco couldn't get me the Energy Saver A/S - they're out of stock at Michelin's warehouses. Hopefully the newer Green X version of these tires don't have too much of an MPG drop.
    Costco was feeding me a line of BS about why the Primacys aren't suited for a Prius - saying our cars are heavy. Well, Michelin did create the Primacy MXV4 to replace the Energy MXV4 series - which are a common tire used on the Mercedes S-Class/BMW 7 Series, and those cars are heavier than a Prius! :rolleyes:
  12. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    Tires are a tough choice. Didn't like OE Integrity at all. Took them off with less that 2K miles. Grabbed a set of 16 inch wheels on a trip to Florida and put a set of 205/55 16 TripleTreds on them. OK tire, excellent directionally and made a big difference on handling in the wet and on highway. They did, unfortunately get very noisy after 10K.
    Replaced early last Summer after a lot of research for a quiet, do all 3 season tire. I came up with a set of Kumho Ecsta Lx Platinums. Stupid name, but it has now ended up on 2 of my cars. Quiet, comfortable, but not squishy. Directionally not quite as good as the TripleTreds... although way better than than the drifty wandering Integritys. The Kumho's wet performance is excellent. MPG was not impacted, so I would imagine that they have low rolling resistance, even though I still run a 205/55 16. After experimenting a bit, I found that 39 psi front and 36 rear worked best between ride, MPG and wear. First time I have ever bought a tire outside GoodYear, Michelin, or Bridgestone.
    Another impressive tire Yokahama S-Drives that my son bought for his car. I think they are even quieter than my Kumhos, but the S-Drives have softer rubber, so they won't last as long. They are also a Summer only tire. Not a cold weather recommended tire. The S-Drives have to be taken off at the first hint of 40 degree temps. My Kumhos are off in Winter, replaced by snow tires.
    I wouldn't hesitate buying another set of Platinums. Even with the goofy name. I'm pretty sure that they may find their way on to a small project car that I have, making 3 cars shod with these tires.
  13. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    I have always ran Michelins on my various Toyota's from my 4-Runner, Corolla, Tacoma to currently both my wife's Prius Touring and my Prius.
    We are both running Michelin Harmony tires currently. She averages about 44 or so with the 205's on her Touring and I get about 47.5 with my 195's. So would highly recommend them.
    For more, hopefully useful information, and to let me know what you think I should do about my tires check out my thread:
    http://priuschat.com/forums/gen-ii-...-tire-question-not-your-typical-question.html
    Happy driving :)
    Chris
