Yet another smart key question
Discussion in 'Gen 2 Prius Main Forum' started by noname87, May 6, 2009.
  1. noname87
    noname87 Junior Member
    84
    NC
    I am thinking of buying a used key from Ebay for my 2008 Prius that has the SKS fob (silver logo). After reading many posts here, I am still slightly confused.
    1) Can the car be programed to accept a used silver logo fob? Would the procedure outlined in other posts for the black log fob work or must a dealer do this? I assume that the fob could only be use to start the car if it is placed in the slot and that all other functions would not work. From reading other posts, i believe that some people have been able to do this. True?
    2) Would a black logo fob also work?
    3) If either 1 or 2 would work, then can I use any key from a 2004-2009 car?
    My goal is a cheap emergency key.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    1) Yes, the car can be programmed to accept a used smart key, but only as a dumb fob. You can't take a used smart key and make it a smart key on another Prius.
    2) Yes, the black log fob would work as above.
    For both of these, you can do the programming yourself. Instructions can be found on PriusChat.
    Tom
  3. noname87
    84
    NC
    Thanks for clarifying this.
    One other question. Can the car be programed so that the lock and unlock buttons work? Other posts suggest that these buttons can be made to work on non-SKS system but I was not sure if it woulsd also apply to SKS cars.
