Yoko to Energy savers
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mitchellsprius, Dec 4, 2010.
  1. Mitchellsprius
    Mitchellsprius New Member
    91
    monterey
    Just wore out my Yoko avid at 44,000. Changed to Michelin energy savers at America tire. I was torn between the Hydroedge and energy savers but American said the Hydroedge was not available from anywhere, just notice Costco has them. The energy are suppose to be made for the Hybrids. Hard to tell in the cold weather about my mileage, I think I can feel a little more roll and quiet. I hope my mileage increases since I have become obsessed with mileage since I got the Prius. Can you let me know what others got from the Yoko and how you like the Michelin energy savers. On another note I change oil at Midas and rotate tires they want 97.00 for the change for the 0-20 oil I thought that was out of line because the other synthetics are the same price. Let me know what your experiences are.
  2. Jerry
    Jerry Junior Member
    17
    Purchase your own oil and bring it with you.
    I'm not keen on the Michelins because they are not H speed rated. H speed rated tires are made to tighter tolerances so they have fewer problems with uneven wear and vibrations. Also H speed rated tires have more material in the tread and bead areas so they are more robust.
    Log entries for Nokian WR-2g severe service all-season tires.
    Date__ODO__INC___MPG (l/100km)
    -- Nokian WR-g2 installed here
    --- Trip to NE starts here
    11/08/08____83688____416____52.5 (4.5)
    11/09/08____84087____399____51.7 (4.5)
    11/09/08____84542____454____54.1 (4.3)
    --- Trip to NE ends here
    11/21/08____85058____515____61.8 (3.8)
    --- Trip to AZ starts here
    12/04/08____85560____501____62.3 (3.8)
    -- 27 F here
    12/06/08____85929____368____53.4 (4.4)
    12/07/08____86322____392____56.7 (4.1)
    12/08/08____86800____478____60.8 (3.9)
    12/13/08____87232____431____57.4 (4.1)
    12/14/08____87673____440____63.3 (3.9)
    -- 25 F here and 50 mph winds
    12/17/08____88133____459____56.3 (4.2)
    --- Trip to AZ ends here
    12/31/08____88629____495____62.7 (3.8)
    -- 27 F here
    01/13/09____89110____487____59.2 (4.0)
    01/26/09____89623____507____58.6 (4.0)
    -- Brake fluid changed, throttle body cleaned
    -- There was an ice day this fill
    02/05/09____90099____475____57.5 (4.1)
    02/19/09____90635____535____62.1 (3.8)
    03/04/09____91135____500____60.7 (3.9)
    03/19/09____91694____559____65.0 (3.6)
    03/30/09____92239____544____62.8 (3.7)
    04/09/09____92752____512____61.0 (3.9)
    04/22/09____93303____550____63.7 (3.7)
    05/08/09____93882____578____65.9 (3.6)
    05/26/09____94455____572____65.2 (3.6)
    -- Spark plugs changed
    06/09/09____95064____608____66.2 (3.6)
    06/13/09____95529____464____57.9 (4.1)
    06/18/09____96021____492____54.7 (4.3)
    06/21/09____96557____535____55.0 (4.3)
    06/27/09____97073____516____57.2 (4.1)
    07/13/09____97681____607____60.9 (4.6)
    -- High temperatures start here
    07/28/09____98245____563____64.2 (3.7)
    08/20/09____98827____581____64.8 (3.6)
    -- Inverter pump changed
    09/08/09____99399____572____65.9 (3.6)
    09/21/09____99951____551____67.7 (3.5)
    -- 16670-21010 Water valve assembly replaced
    --- Four hours of hard rain
    10/09/09____100520____569____63.9 (3.7)
    10/09/09____100967____446____51.3 (4.6)
    --- It snowed here
    --- Trip to MO starts here
    --- Five people plus luggage
    10/16/09____101312____344____51.4 (4.6)
    10/17/09____101759____447____53.8 (4.4)
    --- Trip to MO ends here
    10/18/09____102219____460____54.7 (4.3)
    10/28/09____102716____496____58.5 (4.0)
    11/13/09____103287____567____69.7 (3.4)
    11/24/09____103833____549____67.5 (3.5)
    -- 27 F here
    12/10/09____104297____463____61.0 (3.9)
    12/28/09____104806____501____63.3 (3.9)
    -- 18 F here
    01/10/10____105311____511____57.7 (4.1)
    01/25/10____105787____476____65.2 (3.6)
    02/16/10____106236____448____60.9 (4.6)
    03/07/10____106783____546____62.1 (3.8)
    03/26/10____107335____551____66.3 (3.5)
    04/17/10____107931____595____68.4 (3.4)
    05/13/10____108554____622____69.4 (3.4)
    06/04/10____109194____639____69.8 (3.4)
    06/28/10____109831____637____67.6 (3.5)
    07/28/10____110452____620____67.9 (3.5)
    08/10/10____111064____611____67.2 (3.5)
    08/13/10____111690____625____59.8 (3.9)
    08/14/10____112308____618____60.0 (3.9)
    08/20/10____112972____663____64.2 (3.7)
    08/22/10____113411____438____58.9 (4.0)
    08/31/10____113922____510____61.8 (4.0)
    -- High temperatures end here
    09/24/10____114560____637____70.5 (3.3)
    -- Nokian eNTYRE put on here
  3. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i put on the Michelins in mid October and there has been a slight drop maybe 1 mpg. now that winter is here, the drop is more like 4 mpg. but the driver does not drive efficiently, has heat and defrost on all the time set to 80º etc.
    unfortunately, will probably never find out as it will be sold to sis in mid Jan when the Leaf comes in. different driver, different data. probably hard to correlate
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  5. Mitchellsprius
    91
    monterey
    Okay I have over 400 miles on my Energy savers now and I'm starting to get a better feel for MPG. I put 40.5 PSI in front and 38.5 in rear. Just bought a digital tire pressure gauge. I am bypassing the cold weather reading problem by setting the trip gauge once the car is warmed up. I must say I am getting better MPG, I can go to town about 12 miles and keep it on that 99.9 mark when traffic conditions allow. Haven't taken a long trip just about 25 miles and I can keep it in the 60 to 70 MPG. Of course any hill climbing the MPG drops quickly. But in ideal driving conditions the roll on the tires are better.
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    We have over 30,000 miles on our Michelin Energy Saver tires after
    replacing the factory Yokohama tires, 195x65x15.
    They are smooth riding and we should get at least another 30,000 miles out of them. We have 44 psi on nitrogen (Costco)in all 4 which is max pressure, 44 psi.
    As for MPG we have expierenced at least, 2 mpg increase, probably
    more like 3 mpg has they roll so well at times it feels they
    can roll uphill.
    alfon
  7. Mitchellsprius
    91
    monterey
    Thanks for your input. I went to town tonight and still got 99.9. Yes it is was a little bit down hill and averaging the mileage comming back home brings it down into the 50's. But it is amazing on a straight a way using very little gas. Its like u said maybe 3 or 4 Mpg difference overall but a much bigger difference on a roll without using much gas. What do u think.
