Featured You are Worrying about the Wrong EV Battery
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by drash, Mar 8, 2025.
Tags:
  1. drash
    drash Senior Member
    2,547
    1,292
    Upstate NY
    InsideEVs has an article I know many people will agree with.
    https://insideevs.com/news/752720/ev-12-volt-battery-problems/
    The 12V battery has shown to be a big issue with Hyundai Ionic 5, Kia EV6, Rivian R1S, and Rivian R1T. The article suggests it may be how engineers are not using the DC-to-DC converter correctly or even fault the DC-to-DC converter itself. I did a quick search on this forum and got 100 posts with 12V battery dead.
    I can relate with past experience. All my past Prius suffered from dead 12V batteries within 2 or 3 years, my 2017 Prius Prime's 12V died within the 1st year from a shorted cell. The 12V in my Lexus NX 300h took 5 years before it died but while the article opines it may be the DC-DC converter, I have to disagree, somewhat. It's not the battery location either. The 12V batteries in my 2nd gen Prius and 1st gen Prius Plugin were in the rear, the Prius Prime's was located in the engine compartment. The 12V battery in my NX 300h is in the rear, but I must point out it is the largest 12V battery of my hybrids. In fact Lexus requires a 12V 60Ah 460A CCA (Cold Cranking Amps) while all the rest didn't require any 12V battery with a CCA rating. BTW for further info my 2018 NX 300h is the 1st model year of the 1st generation of the Lexus NXh. I have a tendency to believe the larger batteries have a much larger capacity for wiggle room and can better withstand the constant cycling the article alludes to. The larger 12V batteries found in ICE only vehicles are also made in far greater numbers than the low Ah rated batteries found in EVs and hybrids. Just my 2 cents.
    Tideland Prius, bisco and ETC(SS) like this.
  2. ETC(SS)
    6,903
    This goes all the way back to the G2s
    51,011
    One variable manufacturers cannot account for is downtime.
    A reasonable assessment of average downtime has to be factored in to size the battery considering the battery draw with the car off and potential effects of extreme climate.
    We’ve never had an issue with 3 Prius and 3 hycams over a 20 year span.
    Issues started showing up in gen 4, and seem to have gotten worse in gen 5.
    Judging from the bolt owners forum, Chevy seems to have done a good job engineering the 12 volt system
    Trollbait likes this.
  4. mikefocke
    3,882
    1,749
    Sanford, NC
    I currently run 2 hybrids, had a hybrid before them. Zero 12v issues. Perhaps a relatively mild climate and relatively frequent use. I do suppose they were parked for a 2 week period sometime in their lives with me.
    My 5.8 year old Rav4 hybrid got a new 12v battery at 5+ years just because I felt it was time. No symptom or problem prompted my paranoia beyond I am a storm tracker and have been responsible for knowing the condition of our roads so while others are safe at home, I'm out in all kinds of weather. Her Avalon hybrid of 4 years still has its 12v original battery.
    My Prius v '12 12v battery lasted to the 7 year 60k mark when I sold it.
    Maybe Toyota uses the right batteries and has learned battery management by the time I started buying?
  5. Prodigyplace
    12,390
    11,675
    Central Virginia
    The Gen 4 used a regular flooded battery under the hood. Thay have a shorted lifespan that AGM. From late 2016 to late 2024 I replaced my pabbety once in my 2017 Prius Two.
  6. Tideland Prius
    16,425
    I've never had an issue with the 12V on the Prii I've owned. One lasted 7.5 years before I proactively replaced it prior to a long road trip (6,000km).
    That said, my current EV6 has had a dead 12V already. It's a box standard flooded lead acid, not AGM like the Prius. If it dies again, I'm switching over to an AGM.
  7. Prodigyplace
    12,390
    11,675
    Central Virginia
    When my son had his 2005 Prius, he replaced the AGM battery after 8 years because he did not want to get stuck. It still worked fine, but he figured it was running on borrowed time.
    Tideland Prius likes this.
  8. Trollbait
    12,310
    I wonder if the designers call for one type of battery, then production uses another type without telling anyone. A management system programed for one might shorten the life of another.
    Also can't escape lead is heavy. The factory battery might be undersized as part of a weight cutting effort for fuel economy testing.
    Prodigyplace likes this.
  9. PriusCamper
    PriusCamper Senior Member
    11,977
    4,868
    Pacific Northwest, USA
    Exactly... Wish we still had old @Britprius the battery expert around... Having lived his life in a wheelchair he knew the battery that powered his chair was better suited for a Prius than an OEM. Those of us who took his advice at times got up to a decade of life out of a 12v., because as the article says: "Many are switching toward deep-cycle batteries, which are worse at handling the high-current demand of starting an internal combustion vehicle, but better suited to being depleted more often."
    Of course the problem still remains with G2 Prius because the DC to DC converter gives a pathetically low amp charge to the 12v when the car is running.
    Long ago when your 12v battery died, you'd get a jump start and they'd tell you to drive the car around for 20 minutes before turning it off to recharge it But in an old Prius you'd have to drive it around for 8 hours to get the same amount of charge.
    Perhaps the root of the problem is that a gas engine with an alternator can produce huge amounts of excess energy and with an old school lead-acid 12 volt your didn't have to worry about dumping too much power into it.
    But now that the alternator is in the electric motor powering the vehicle directly there's lots of times when it's accelerating and consuming power and only generating power when decelerating and all the designers keep underestimating how much of a problem that can be...
    #9 PriusCamper, Mar 8, 2025
  10. Trollbait
    12,310
    Perhaps it is time to stop delaying the switch to 48V systems. It was considered in the past because of increasing loads from accessories, but the suppliers managed to make those more efficiency instead. Well, we've just been adding more accessories.
  11. Tideland Prius
    16,425
    Also, cost.
    We’re also the only market that I’m aware of that has a 12V battery management system whereby the HV battery charges the 12V battery while parked if necessary (the orange light on the dashboard). Not sure what we have in our cars that other countries don’t that would increase the phantom drain of a 12V.
  12. hill
    8,613
    Same here, regardless of whether it was Lexus Hybrid / Toyota hybrid / GM hybrid / Chrysler hybrid. Never changed the battery until a minimum of 6 years old. Maybe just lucky?
    Tideland Prius and Prodigyplace like this.
  13. Prodigyplace
    12,390
    11,675
    Central Virginia
    The newer ones have all thau always on subscription stiff with the app. They need to keep checking in with cloud servers. That costs electrical drain, among other things.
  14. PriusCamper
    11,977
    4,868
    I suspect an exponential increase in 12v systems would create more problems than it solves. Cybertruck is not doing well with most aspects of this system.
  15. Trollbait
    12,310
    The Cybertruk can have its stainless steel skin peeled off and lose its bumper when towing. I would not use it as an example for any other system.
    48V mild hybrid system use is expanding, and will become the typical car in much of the world's auto markets. Is there a reason to stick with 12V when a company's production all have a 48V system onboard?
  16. ETC(SS)
    6,903
    You're going to have to convince big battery AND the OEMs.
    Right now people are willingly buying cars without spare tyres.....to save weight, of course (wink,wink!)
    Some otherwise intelligent people are not even settling for wimpy little doughnuts.
    Batteries are much the same.
    Oh - you HAVE to have one but they're often as not very GOOD ones, even some of the AGM (absorbent glass matt) batteries are failing earlier and earlier - and the OEMs are only incentivized to have them work properly during the warranty period.
    Customers are self installing more and more alarm systems, amps and subs, cameras, refrigerators and heaters, and on and on and on.
    Me?
    I have and keep a jump pack and I make sure that the one in my CFO's car is charged and ready to go.
    It's cheap insurance.
    Even my budget $50 unit has been solidly reliable over the last 5 years.
    I keep a more premium ($100) jump pack in my CFOs car.
    If this were a problem that OEMs were incentivized to solve then cars could be equipped with an onboard jump pack at scale for $25-50 or so per unit.
    Lots cheaper than switching to a 48VDC electrical system.
    hill and Prodigyplace like this.
  17. Prodigyplace
    12,390
    11,675
    Central Virginia
    I would rather that as an option instead of the $90 for 3 USB-c cables that is one Camry option some regions force on people.
  18. mikefocke
    3,882
    1,749
    Sanford, NC
    You forgot the pouch of car care products that also come with some SET vehicles.
  19. ETC(SS)
    6,903
    My last GMC came with a full size spare.......as do Ford Lightnings and Cybertrucks....IIRC.
  20. Prodigyplace
    12,390
    11,675
    Central Virginia
    I was thinking of SET. since I am close to the NC border, I started looking down there until I saw all of the added cr*p!. I ended up with a Camry XLE with just the 2 options I wanted. Premium Plus Package & the all weather floor mats. Not from SET though.
