Your Volume Setting?
Discussion in 'Gen 2 Prius Audio and Electronics' started by stomsf, May 11, 2007.
  1. stomsf
    stomsf New Member
    50
    Just curious, what is your most often used volume setting?
    As I primarily switch between my DICE and the radio, I have to turn volume up for the DICE to about 38-40 and on radio it goes to 26-30 most of the time.
    If it's a song I really like I've been up to 50 on the DICE and 38 on the Radio.
    Just wish I could somehow boost the output from the iPod without losing the MFD display of the songs. :blink:
  2. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(stomsf @ May 11 2007, 06:35 PM) [snapback]440251[/snapback]</div>
    you could try adding an amp.
  3. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    mine goes to 11
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    12. I usually have it somewhere around 10 to 12.
    Tom
  5. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(priusFTW @ May 11 2007, 07:00 PM) [snapback]440325[/snapback]</div>
    The Prius already has an amp.
  6. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    count me in with the self-induced hearing damage group...
  7. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    Depending on the song....40-50.
    What I would love though is a feature where the volume would fade up when you switch audio on. I often switch the audio off whn I park cause being a man, I can only do one thing at a time. When I switch the audio on again I get a sonic blast and have to jump for the volume button.
  8. Tideland Prius
    16,155
    15-20 for CDs/MP3
    20 for radio
    30 if I feel like pumping it up although anything about 25 can be heard outside the Prius... seriously, try it some time. There's no dampener between the doors.
  9. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    <div class='quotetop'>QUOTE(Vagabond @ May 11 2007, 10:26 PM) [snapback]440422[/snapback]</div>
    It's kinda crappy, though... It'd be lucky if we even get 20 watts RMS from that :)
  10. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    My kids have no trouble knowing where I'm parked when I come to pick them up. I'd crank it louder if the sound quality were better. What road noise? Is it the back window that's vibrating, or the rear view mirror? B)
  11. mpgFanatic
    mpgFanatic New Member
    112
    OFF
  12. aaf709
    3,862
    2022 Prius Prime
    30-35 for the radio and the DICE (when it's in AUX mode). If I'm using the iPod it's generally between 30-35, unless I'm listening to Fibber McGee & Molly, where I may have to go to 50 (they were recorded at a very low volume).
  13. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(aaf709 @ May 12 2007, 12:27 PM) [snapback]440669[/snapback]</div>
    On the DICE, you can adjust the volume levels coming from the module by going to DISC 1 while using the AUX jack.
    <div class='quotetop'>QUOTE(Presto @ May 12 2007, 11:27 AM) [snapback]440653[/snapback]</div>
    Can't argue with that.
