Power Steering High Pressure hose Pipe
Honda Accord MK8 2004-2008 Power Steering High Pressure hose Pipe:
The power steering pressure hose is carries hydraulic fluid from the power steering pipe to the steering gear. It maintains the fluid under high pressure and can sometimes fail, causing issues with the power steering and steering gear.
Detail
A power steering pressure hose pipe is a component within a vehicle’s steering wheel system. It helps to transport hydraulic power steering fluid to the power steering rack and power steering pump from the reservoir. This fluid only works in a pressurized system.
Any vehicle comprises two power steering pressure hoses:
1. The High-pressure hose.
2. The Low-pressure hose.
The high-pressure hose transports fluid from the pump to the rack.
The low-pressure hose is mandated for transporting fluid back from the rack to the pump.
Detail: The high pressure hose is manufactured to withstand higher pressure and temperature than the return hose. At any time, temps may be over 270 degrees and there can be over 1500 psi. Power steering fluid is highly flammable so hose integrity is a must. It carries the fluid under pressure to the steering box. The low pressure or return hose, does just that returns the fluid to the reservoir. It does not carry fluid with temperatures and pressure as high as the high pressure hose, so it is manufactured to withstand the decreased strain.
Main Purpose of Honda Accord high Pressure Hose Pipe:
The high-pressure (supply) hose carries high-pressure oil from the power steering pump to the steering gear. The low-pressure (return) hose carries oil from the steering gear back to the pump or its reservoir.
When to the consider replacing the Power Steering Pressure Hose Pipe:
Groaning, whirring noise or difficulty steering
Noise, or difficulty turning the steering wheel, may reflect a low power steering fluid level, which could be due to a leak in a pressure hose, or a leak elsewhere in the power steering system. Although a leak in the pressure hose is a possible cause of a low fluid level, a mechanic will also consider all other possible causes.
Visible fluid leaks
There are usually steel ferrules clamped onto each end of the rubber pressure hose. These ferrules are common leak points. If there is seepage from these ferrules, the mechanic should replace the pressure hose.
Hose damage. If the hose has significant physical damage, such as cuts, abrasions, cracks, or heat damage, the mechanic should replace the hose to avoid sudden hose failure.
Contaminated fluid
If rubber particles are found in the power steering fluid or reservoir, it means the interior of either the pressure hose or the return hose is deteriorating. The mechanic should replace all rubber hoses and the system flushed. An in-line, aftermarket fluid filter might be required.
Hose age
Both the pressure and return hoses are rubber-based products with a limited service life. If the vehicle is more than 10 years old, and power steering components are being replaced, all the rubber hoses should be replaced during that service.
Maintenance Tips/Suggestions
Check the power steering fluid level at every oil change and inspect the hoses regularly. When checking the hoses, look for leaks, rusted or corroded fittings, sponginess, stiffness, and cuts and abrasions. If Honda accord hatchback, saloon or estate Hoses showing any of these conditions should be replaced. Refer to your car’s owner’s manual for specific recommendations on the type of power steering fluid to use.
Fluids need to be compatible with hoses and seals and in some cases the recommended fluid may be automatic transmission fluids. It’s possible to check the power steering fluid level when your car is cold, but it’s usually recommended to check the fluid with the car warmed up. Many cars today use a semi-transparent reservoir for power steering fluid, so look for a fluid level mark on the outside. If the reservoir has no markings, open the reservoir's cap. There should be a small dipstick attached that provides the level reading. Use care not to run the system low on fluid; insufficient fluid level can damage the power steering pump.
How to replace the power steering pressure hose?
The under hood routing of the power steering pressure hose pipe varies greatly between car models. The repair procedure ranges from simple to quite involved. The basic steps are:
• Raise car as needed and support with steel safety stands.
• Unthread the pressure hose tube nuts, or banjo-style bolts, at each end of the pressure hose.
• Remove pressure hose and inspect interior hose lining for separation, if visible.
• Install a new hose, using a new sealing washer or O-ring seals as applicable, and paying particular attention to the required original equipment manufacturers (OEM) torque value for the tube nuts or banjo bolts. Replace rubber return hose, if required, and with the authorization of the customer.
• Once the system is fully sealed, bleed or flush the power steering system as required to remove all air and contaminants.
• Finally, the engine is run, the car is test driven, and leaks are checked for at all connections.
When replacing the power steering pressure hose keep in mind:
When the power steering hoses are replaced from Honda accord Mark8 2.2 diesel 2004-2008
• , the entire power steering system should be inspected.
• Use only OEM specified power steering fluid in your power steering system.
• If the pressure hose has deteriorated from the inside, the rubber return hose should be replaced as well and the system should be flushed. A mechanic might recommend the installation of an in-line filter to capture all debris.
• Tube nuts and banjo bolts used to seal pressure hoses have OEM-specified torque values. Mechanics will use a calibrated torque wrench to tighten the connections.
• Completely removing the air from the system can occasionally take some time, even after the normal bleeding procedure. During this time some mild noise may be heard when turning the steering wheel. If it persists more than a day or so, the mechanic should recheck the system.
Main Dealer Part Numbers
53713-SEF-E01
53713SEFE01
ALL Honda Accord MK8 CM1 CM2 CN1 CN2 2004-2008
Shape All 4 Door Saloon, 5 Door Estates and 5 Door Hatchback Models
Fuel Type All Diesel Engines 2.2
Fitment Years 2004, 2005,2006,2007,2008
Image:
Power Steering Pressure Hose Repair Cost
If you want a cheaper, less expensive, and temporary alternative to replacing the hose, or if you need an emergency repair, then you can fix the hose yourself. All you need is to find a local auto store and a few parts that can let you easily cut down on the total power steering pressure hose replacement costs.
Then you need to find the portion of the house with the leak and cut off the section that’s bad or potentially leaking. Insert the coupler inside the hose in the post you count out the hose and tighten each side via a hose clamp. This can give you a temporary power steering pressure hose repair and give you a short term solution.
Power steering rack and pinion repair cost
The average cost to repair a leak on a steering rack and pinion assembly will usually run between $500 and $1000, which is much more expensive than other parts of the power steering system and the overall power steering pressure hose replacement cost.
Conclusion:
If the power steering pressure hose has failed, you will usually notice severe issues with the performance of your vehicle. If the problem has directly affected the power steering pump, it will make a loud noise and might be difficult to turn the wheel. Figuring out the causes of a faulty power steering pressure hose can help you keep your car working at a high level for a long period of time!
Is it safe to drive with a power steering pressure hose problem?
No. The fluid in the power steering pressure hose is under very high pressure and flammable. A leak that sprays fluid into a hot engine part, such as the exhaust manifold, can cause a fire. Leaks that cause significant fluid loss can cause difficulty in steering. If a leak causes the fluid level in the reservoir to drop too low, it can cause damage to the power steering pump, necessitating the installation of a new one hose and a new pump.
If you notice any of the above signs that means it’s time to bring your car to a mechanic to get your power steering pressure hose replaced. The best way to book car maintenance is by booking your services through www.ecobreakers.co.uk or click on below links
EcoBreakers | NEW & USED GENUINE CAR PARTS WITH THE MOST COMPETITIVE PRICES
Jun 5, 2023
