2012 Prius C with 245,000 just stopped.
Discussion in 'Prius c Technical Discussion' started by Joni Renee, Apr 11, 2024.
  1. Joni Renee
    Joni Renee Junior Member
    The yellow check engine light came on...then the check ev system in yellow. Then a bunch of light and it won't start. Someone ran a code machine and it cited the H20 pump? Is there a system / battery shut down that overrides the car and keeps it from starting? IMG_20240408_083325392.jpg
  2. Leadfoot J. McCoalroller
    6,923
    6,546
    Pennsylvania
    2018 Prius c
    Technically there are many.
    Somebody is going to have to connect to the onboard diagnostic system and ask the car what it thinks is preventing the car from going into READY mode.
    You can get inexpensive bluetooth devices and smartphone apps that can do this on your own. Some are better than others. There is a thread on this board with details, but I do not keep current on the results.
  3. Sonic_TH
    Sonic_TH Active Member
    532
    83
    Puerto Rico
    Probably the hybrid battery if it has not been replaced. Or maybe the inverter, i suspect 1 of the 2.
  4. Brian1954
    Brian1954 Active Member
    698
    263
    South Central PA, USA
    https://priuschat.com/index.php?posts/3246758
  5. Chucktr
    Chucktr Junior Member
    2015 Prius c
    OK, not answering your question. Sorry! But 245K?!? Is this in the "normal" range for a Prius?
  6. Leadfoot J. McCoalroller
    6,923
    6,546
    Pennsylvania
    2018 Prius c
    I tell everyone to pay attention to the calendar rather than the odometer.
    The normal range for a Prius is all the miles you can drive in about 15 years.
    A few only go 12 and a very few make it past 20.
    Chucktr likes this.
  7. Chucktr
    2015 Prius c
    Our outstanding 2015 was totaled last week. Now looking for a used 2015. Don't like the styling changes since. Seems there are a few around.
    Insurance will pay.
    Thanks!
  8. rjdriver
    rjdriver Active Member
    402
    167
    Rhode Island
    If I'm reading your code result correctly, then the car will not start if the water pump has failed. You can probably override it by having a mechanic reset the code, or maybe even by disconnecting the battery for a few seconds. But I wouldn't do it. It will just shut down again when the coolant reaches a certain temperature, and you risk damaging the engine.
    It's probably close to $1000.00 to replace the pump. I would get a second code reading to confirm, and then decide if you want to make the investment.
  9. Mendel Leisk
    Mendel Leisk Luddite
    38,376
    Did someone seriously call it that?
  10. Leadfoot J. McCoalroller
    6,923
    6,546
    Pennsylvania
    2018 Prius c
    Sorry to hear you lost the car, glad you made it!
    Let us know when you find a replacement?
  11. rjdriver
    402
    167
    Rhode Island
    It had me confused at first. Was thinking "is that some kind of new code I haven't seen before?". Then it hit me "Water Pump!" Maybe its something entirely different, but figured I would offer my two cents just in case.
