2017 Prius Prime 11.6 Information screen
Discussion in 'Gen 4 Prius Audio and Electronics' started by Aaron#44, Apr 26, 2022.
  1. Aaron#44
    Aaron#44 New Member
    Englewood, Co
    My screen has gone out, my mirrors don't work and both my cigarette lighters and USB charging ports are also not working. Does anyone know exactly what fuse or module would have burned out and where it is located? So far I have only checked fuses all the ones under the dash at the drivers left leg. Plus all of the fuses in the main box in the engine compartment on the top right side. I can't find any other information online. I thought I would ask before I start tearing things apart. Thanks in advance if anyone has the information I'm looking for sure would appreciate it.
  2. Marine Ray
    Marine Ray Senior Member
    1,139
    940
    Sparks, NV
    There's also a fuse box on the left side of the engine compartment.
  3. AJB68
    AJB68 New Member
    Bainbridge Island, WA
    Wondering if anyone has a fix for this as I have just experienced what seems to be the same issue with my 2017 Prime Advanced. While adjusting wing mirrors they stopped adjusting and the screen shut down. USB port and speed indicator on HUD also not working.
    Thanks in advance for any recomendations. .
  4. AzWxGuy
    AzWxGuy Weather Guy
    973
    494
    Tucson, AZ
    2021 Prius
    First thing I would check would be the 12V battery voltage. With the Prius off, and no draw on the battery, the voltage should be 12.4V or better. Any time you start getting electrical gremlins acting up, better check that battery.
    Oh, and welcome to PriusChat!
