Is Gen 5 Prius really better-looking than Gen 4 Prius Prime?
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, May 24, 2023.
  1. Trollbait
    11,390
    The Touring and Limited trims had P215/45R17 tires. The Eco and the rest had P195/65R15s. The larger and heavier trims were very likely what was used for the non-Eco mpg tests.
    The gen 5 uses the same battery, has a greater weight difference, with the same 2 inch increase in wheel size, though the tires stay the same width. Its LE actually has a slightly better improvement over the other trims than the gen4 Eco.
    The difference the Canadian Camry Hybrid LE and the US LE fuel economy is greater that between the Canadian LE and the XLE and XSE, with heavier weight, bigger wheels, and NiMH battery.
    Any Coulombic efficiency advantage to Li-ion appears to be small. Considering the slow acceleration and deceleration rates of the EPA tests, it might not even show up there.
  2. Gokhan
    Gokhan Senior Member
    4,455
    1,803
    Paramount CA
    That is a hyperbole to claim that Toyota would have used the wheel size found only in a small fraction of cars (Three Touring and Four Touring) and use it to label all cars for a given model.
    A 30% difference in Coulombic efficiency for lithium-ion vs. NiMH is a lot. If the hybrid gains are around 15 mpg, it would make a difference of 4.5 mpg, which would explain the difference between the Eco (lithium-ion) and non-Eco (NiMH).
    #382 Gokhan, Apr 14, 2024
    ukulelegeek likes this.
  3. Trollbait
    11,390
    What evidence do you have that they didn't?
    The tested weight of the 2020 Eco was 3250, and the other Prius used was 3375.
    Data on Cars used for Testing Fuel Economy | US EPA
    That's 240 and 300 pounds more than listed curb weight. The 60 pounds difference is from the other test Prius being equipped with all the options.
    The coulombic efficiency of NiMH can approach 90% with fast charging, and the energy efficiency of Li-ion will drop with faster charging(your source). Then the numbers cited are general ones, and not the actual ones for Toyota's batteries.
    Since you refuse to address the points I raised with the Camry and gen5, why is the Eco the only one with a higher rating? It isn't the only gen4 using the Li-ion battery. It appears most did. So why aren't they rated as high as the Eco if it is all about the chemistry as you claim?
  4. ukulelegeek
    ukulelegeek Active Member
    152
    104
    I can't imagine anyone not loving that color.
    Gokhan likes this.
  5. Gokhan
    4,455
    1,803
    Paramount CA
    Here is the vehicle data. Search for the 2016 model year, Toyota, and Prius.
    Basic search | Document index system | US EPA
    They actually tested Prius Two (NiMH cells) separately, but they grouped Prius Eco, Prius Three/Four, and Prius Three Touring/Four Touring (all Li-ion cells) together. Note that only Three Touring and Four Touring had larger tires/wheels. Only Prius Two had NiMH cells.
    So, the Toyota/EPA tests seem to be a soup. However, it looks like “Prius” refers to Prius Two (NiMH cells) and “Prius Eco” refers to the average of Prius Eco, Prius Three/Four, and Prius Three Touring/Four Touring (all Li-ion cells).
    Therefore, once again, the reason for the different EPA numbers seems to be because of the Coulombic efficiency of NiMH cells (Prius Two) vs. Li-ion cells (Eco, Three/Four, and Three Touring/Four Touring grouped together and averaged by Toyota/EPA).
    Weights for the different trims according to the 2016 brochure are as follows: 3075 lb, 3010 lb, 3050 lb, 3080 lb, 3050 lb, and 3080 lb for Eco, Two, Three, Three Touring, and Four Touring, respectively. These are negligible weight differences to make a difference, especially for a hybrid with regenerative braking that does not lose much energy through friction braking, where the weight becomes more important.
    It is not the aerodynamics of the rear wiper either, as you would have seen it mainly in the highway mpg numbers if that were the case.
    It is apparently not the wheels/tires either, as Toyota/EPA chose to group Eco together with Three/Four and Three Touring/Four Touring. In other words, Toyota/EPA separated the trims only by the cell type (NiMH or Li-ion) and did not care about the wheel/tire size, rear wiper, weight differences, etc. Therefore, once again, it looks like it was the Coulombic efficiency of the NiMH vs. Li-ion cells that made the difference in “Prius,” which is apparently Prius Two (NiMH cells) as actually tested, and “Prius Eco,” which is apparently the average of Prius Eco, Three/Four, and Three Touring/Four Touring (all Li-ion cells) as actually tested.
    Check out the data for yourself if you like:
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=36706&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=36707&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=43214&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=43215&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=43216&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=43217&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=36143&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=36144&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=36460&flag=1
    https://dis.epa.gov/otaqpub/display_file.jsp?docid=36461&flag=1
    #385 Gokhan, Apr 14, 2024
  6. Trollbait
    11,390
    Those are applications and certificates for the emissions. Only the cold test had fuel economy results. The different batteries mean different emission systems.
    In the fuel economy database for 2016, there are three test Prius. A Two, Eco, and another from the Eco's test group.
    Reported results for the Two.
    city test: 64.9 and 77.3
    highway test: 63.6 and 76.1
    The Eco
    city: 71.1 & 78
    highway: 66 & 71.2
    The Other was only used for the cold and air conditioning tests. Which weren't done with the Eco. I'm guessing it is another Eco as the first only did the high speed in addition to the base city and highway, and these cold and A/C results are better than the Two.
    Looking further at the emission paperwork, These three test vehicles were used for those certifications. The Eco results were allowed to be used to cover the others for emissions.
    Toyota surely did do some fuel economy testing with the others. They couldn't have been notably better if they decided to group them with the Two for window sticker rating.
  7. Gokhan
    4,455
    1,803
    Paramount CA
    If only Two and Two Eco were tested, then the difference in mpg is definitely because of NiMH vs. Li-ion Coulombic efficiency, respectively, as the wheels/tires are the same, and the weight difference of 65 lb (primarily due to the spare tire) is negligible.
  8. Trollbait
    11,390
    Yet Li-ion, plus smaller wheels, thinner tires, and lighter weight, only gets the Canada Camry Hybrid LE 4.2% better fuel economy than the higher trims to the Eco's 7.7%. The even smaller wheels and thinner tires of the American LE get to 13%. Which is what started this side discussion, Toyota putting more effort into the American LE to get above 50mpg.
  9. Gokhan
    4,455
    1,803
    Paramount CA
    You can see the effect of the wheel/tire size in the nonhybrid models. The rest of the effect is coming mainly from the Coulombic efficiency of the lithium-ion vs. NiMH cells. Naturally, the wheel/tire size effect is more important in the highway mpg and the Coulombic efficiency is more important in the city mpg.
    Toyota/EPA mpg data for the Gen 4 Prius/Prius Eco is a mess. When the test data doesn't even explicitly (in fact, even implicitly) show what model was actually tested, you know that the data is part garbage.
    2025 Camry will eliminate the NiMH cells, and it will be interesting to see the new mpg values across the trim lines. Hopefully, it will beat the previous generation in mpg.
    Now that we discussed the Li-ion cells, that could also be why the Gen 4 Prius Prime (with Li-ion cells) got a higher mpg than Gen 4 Prius (apparently Prius Two with NiMH cells as tested) despite the heavier weight of the former arising from the much larger battery pack.
    #389 Gokhan, Apr 15, 2024
  10. Trollbait
    11,390
    Later model years in the fuel economy database do differentiate between the Priu s and Prius Eco.
    The Camry Hybrid LE already uses Li-ion. Looking at the US and Canada versions with the XLE/XSE shows that wheel size plays a bigger part in the LE's better efficiency than battery chemistry. Then much of the improvement of this gen from the previous came from the upgrade in engine technology. The 2025 X trims might reach the 50mpg hurdle from the mid-forties they are at now. The LE could beat the Prius XLE, but not the Prius LE. It won't be cheaper than the Prius.
  11. Mendel Leisk
    Mendel Leisk Luddite
    38,376
    Maybe worth noting: in Canada (shades of Henry Ford?), you can get any gen 5 non-plug-in Prius you want, as long as it has 19" wheels, and AWD.
  12. Trollbait
    11,390
    Along that line, Japan can get any Prius Prime, as long as it is the top trim.
  13. dbstoo
    dbstoo Senior Member
    1,290
    686
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    That does not wash. The Prius is close to the same size as the Camry. The term 'tiny car' should be reserved for the sub-compacts. A "Think" is a tiny two seater. So are some of the BMW models. The Tesla Model 3 is smaller than the 2024 Prius, yet I'm not seeing the term "tiny" applied to any of the Tesla models.
    GcinFl and Gokhan like this.
  14. Gokhan
    4,455
    1,803
    Paramount CA
    EPA tested the Gen 4 Prius only in 2016.
    No, it doesn't. As I said, look at the US EPA mpg values for the nonhybrid trims. There, you can entirely isolate the wheel/tire-size contribution. It is 6%. That leaves a Coulombic-efficiency contribution of Li-on as 7%.
    OK, compact vs. midsize.
    #394 Gokhan, Apr 15, 2024
  15. Trollbait
    11,390
    Except the hybrid LE in the US isn't using the same wheels as the ICE LE, which is why I was bringing up the Canadian hybrid LE.
    With the ICE LE getting a 3.2% improvement over the XLE, that leaves less than 1% due to the battery, as there is also the engine efficiency of the Atkinson cycle in the hybrid.
    The gen5 is an EPA midsize like your gen4. The total volume is almost the same as the Camry's. It just has more cargo space and less cabin.
  16. dbstoo
    1,290
    686
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I remember from my youth that the easiest way to change the performance of a car is to change the back end gear ratio. The easiest way to change the gear ratio? Simple. Put larger diameter tires on the driving wheels. For each revolution the car will move further.
    On my car, it looks like the 19 inch rims with the lower aspect ratio tires move the same distance as the smaller rims with a higher aspect ratio.
  17. Gokhan
    4,455
    1,803
    Paramount CA
    Your calculations are not correct.
    First, you need to understand that there is a lot of uncertainty in these measurements.
    Second, the uncertainty is even bigger if you want to compare two separate measurements. For example, if the uncertainty in each measurement is 5%, then the uncertainty in the comparison will be 7% (greater by a factor of √2).
    That said, these are the numbers for the combined mpg:
    Canada 17" nonhybrid: 39 mpimpg
    Canada 18" nonhybrid: 38 mpimpg
    Canada 17" to 18" wheel penalty: 2.6%
    Canada 17" hybrid: 58 mpimpg
    Canada 18" hybrid: 55 mpimpg
    Canada wheel and NiMH Coulombic efficiency penalty: 5.5%
    Canada NiMH Coulombic efficiency penalty: 2.75%
    US 16" nonhybrid: 34 mpg
    US 17" and 18" nonhybrid: 32 mpg
    US 16" to 17" or 18" wheel penalty: 6.25%
    US 17" to 18" wheel penalty: 0%
    US 16" hybrid: 52 mpg
    Canada 18" hybrid: 46 mpg
    US wheel and NiMH Coulombic efficiency penalty: 13.0%
    US NiMH Coulombic efficiency penalty: 6.4%
    So, the wheel and NiMH Coulombic efficiency penalties are about half and half for both Canada and US.
    Again, realize the uncertainty in these numbers, and don't take anything reported as gospel. I suspect at least a 5% uncertainty for individual numbers and 7% for comparing two numbers. Therefore, most of these differences are within noise.
  18. Mendel Leisk
    38,376
    This is news to me; I thought they used 15” rim model. Could be wrong.
    With Gen 3 and 4 the 17” rim/tire combo has slightly smaller OD, versus 15”. With Gen 5 it’s the reverse: 19” OD is greater than 17”, and the difference is more, close to 1/2” for the OD’s IIRC.
    Gokhan likes this.
  19. Trollbait
    11,390
    My math was not wrong.
    I only had numbers for the 2024 Canadian models so used 2024 US Camry, which has no 16" wheel models listed. I also converted the the Canada L/100 km to standard mpg and rounded them like the EPA in another post, and used those figures(Canada LE is rated 48 city/49 highway/ 48 combined).
    The 2024 18" is 31mpg combined compared to the 17" 31mpg. Making the smaller wheel improvement 3.22%. 18" to 16" is a 9.7% improvement. That extra inch in wheel size reduction and skinnier tires triples the one inch difference improvement. Little weight changes to unsprung weight have a bigger impact than the raw numbers imply.
    This all started cause I said Toyota put more effort into the US Camry Hybrid LE than the Prius L Eco(post #373). They just swapped the battery from the NiMH in the fleet sales Prius L. The Camry got the battery swapped and got the wheels from the fleet Camry. Toyota Canada didn't feel compelled to use the cheap wheels on a car that might be coming out of the same factory.
  20. dbstoo
    1,290
    686
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Mea culpa. I did not double check any of the dimensions for the 2024 XSE 19 inch tires VS the ECO tires.
    Bringing it back to the thread title... no one said that they thought my 2017 Prius Prime looked great. They thought it looked different. They thought that it did not look like a Prius. A few thought that it looked more like a sports car than the Gen 3.
    In the two months that I've had the fifth generation Prius Prime, I've had many compliments on it's over all looks, and many focused how good it looked with those rims.
    Keeping it in perspective... I drove a GEN 1 Prius for more than 17 years and I liked it. I drove a Gen 4 Prius for 4 years, and I enjoyed it. I can only guess that my body type is close to what the Japanese use when determining the ergonomics for their cars. :)
    #400 dbstoo, Apr 16, 2024
