Audio and Electronics This is a discussion on Question on 12V outlets within the Audio and Electronics forums, part of the Toyota Prius Forums category; I finally got one of the Lentek AP01 Auto Power charger / vacuum / inflator / emergency light units, and ...
Old 04-09-2004, 09:42 PM   #1
mikepaul
mikepaul's Avatar
Default Question on 12V outlets
I finally got one of the Lentek AP01 Auto Power charger / vacuum / inflator / emergency light units, and I need some info on how I'd use it on a dead battery.
As delivered, it requires that the 12V outlet in the Prius be active so it can be plugged in there to jump the car. As I understand it, the outlets in the Prius aren't active (all the time) unless you do something about it. The MULTI5.PDF in the library doesn't show it being a dealer-settable option like I remembered.
So I need to either:
1) Get the 12V outlets active somehow.
2) Cut the cord off just before the 12V input and replace it with clips suitable to attach to the Prius' normal jump points.
(suggestion from Prius-2G group)
3) Get a female 12V adapter from Radio Shack, and wire it to the jump terminals along with a fuse to prevent accidents.
The 'clip' job may not fit into the AP01's storage base. Not thrilled with the Radio Shack idea. Has anybody out there already made the outlets hot all the time and/or can tell me how it's done?
Thanks...
2004 Seaside #9/BC as of 1/3/2004
Oil now any GOOD synthetic I can get on sale
Goodyear TripleTred 195/65R15 tires since 5/19/05
80,000 miles as of 8/22/2008
mikepaul is offline
Old 04-09-2004, 10:48 PM   #2
riskable
Send a message via AIM to riskable Send a message via Yahoo to riskable
Just curious: Why are you so worried about having to jump start your Prius? You live in northern Canada?
riskable is offline
Old 04-10-2004, 03:06 AM   #3
Coastal Dave
The power outlets in the 04 Prius are actually separate circuits. The one up front is powered continuously but kept from being active by a relay whose coil is controlled by power going to the second outlet in the console. The console outlet is powered by the accessory 12V which is only active when the car is powered up. In this way, the accessory position(mode) will provide power to the console outlet which in turn energizes a relay controlling the power outlet up front and allowing it to be active. The power outlets are fused separately and the fuses are electrically before the relay which does make it more convenient for modification. If you want to make the the front power outlet remain on continuously, all you have to do is clip a jumper wire across the contacts on it's relay. The physical location of the relay is way up in the dash and requires a bit of work to get to but you really don't have to take it all apart to accomplish what you want to do. The power outlet 12V constant source wire going to the relay is located on a plug just behind the fuse box under the edge of the dash on the driver side. It is even on the bottom plug so you don't have to take any panels off to get to it. You will have to pop the panel out where the power outlet is located to clip the other end of your jumper wire but that is quite simple. If you would like, I can put together a few pictures which show where to connect to. Don't power the console outlet continuously because, as I mentioned earlier, powering it up will turn on a relay which turns on the front outlet, not to mention turning on everything else in the car which is attached to the accessory mode power. On the other hand, jumping the contacts on the front power outlet relay will not cause an extra power drain on the car because the front outlet is isolated from the console outlet by the relay and is not connected to the accessory power wiring as is the console outlet. Of course, if you install the jumper don't leave anything plugged in to the outlet which could cause a significant power drain when the car is off.
Coastal Dave
www.coastaletech.com
Coastal Dave is offline
Old 04-10-2004, 09:52 AM   #4
JJay
JJay's Avatar
Hey Coastal Dave,
If you could post a few pictures, that would be great!
I'm not trying to jump start my car, but would like to charge my cell phone overnight. Hopefully that doesn't fit into the category of "anything plugged in to the outlet which could cause a significant power drain when the car is off" !
Thanks,
Jay
JJay is offline
Old 04-10-2004, 11:03 AM   #5
mikepaul
mikepaul's Avatar
Sounds like something for you to do when I'm down there to get one of the audio/video mods put in. If you're ready by July, when I can take a day to come down.
Thanks...
mikepaul is offline
Old 04-10-2004, 11:05 AM   #6
mikepaul
mikepaul's Avatar
Possibly I'm overly-concerned, but stuff happens...
mikepaul is offline
Old 04-10-2004, 02:44 PM   #7
8AA
8AA's Avatar
Coastal Dave,
Thanks for the useful information. I'm sure that it will save some people a lot of headaches and frustration.
Bob
8AA is offline
Old 04-10-2004, 09:49 PM   #8
Coastal Dave
I'll get some pictures for you tomorrow of the jumper location. I had the computer with all of the pictures and notes loose a hard drive yesterday so I'm still in restore mode : ) Luckily the bad sectors didn't affect most of the data but it's a real pain to gather up all of the software and backups and odd CD's to get a new unit up to speed.
Old 04-12-2004, 07:08 PM   #9
JJay
JJay's Avatar
Thanks Dave!
JJay is offline
Old 04-12-2004, 09:56 PM   #10
Coastal Dave
Here are a couple of views from behind the fuse panel in the '04 Prius. If you lay down on the driver side floorboard and look up, there it is. Adding a jumper from the light green wire shown to the WHITE wire on the front outlet will allow a direct connection to the 12 volt battery for continuous power and the ability to jump start the car through the outlet if necessary. You could even charge through the outlet with the proper regulated unit if needed to maintain the battery for extended periods of time. Care should be taken not to connect the green wire to the white with black stripe wire on the power outlet. This is the ground so double check that you are jumping to the solid white wire and that it has no black stripe on it. The fuses for the front and console outlets will still be operational and protecting their individual outlets even with the jumper in place. I'm going to go ahead and make a jumper kit available on the website if you don't have the parts already. To get to the power outlet remove the ribbed pin located below the power outet and forward on the corner. Then pull the lower section of the dash free from it's clips. The back of the power outlet is now visible. A piece of tape is folded over the two wires leading to the outlet. Separate it and install a tap on the white wire. Plug in your jumper and attach the other end to the light green wire described in the photos using a wire tap. Then you can always remove the jumper if you want to and you haven't cut any wires. I mentioned it in an earlier post but just as a reminder, don't hook a constant source jumper to the outlet in the console. It is wired differently and hooking a jumper up there would power several other circuits causing a power drain.
Power Outlets casinada Knowledge Base Articles Discussion 8 05-11-2007 10:24 PM
Preferred Service Outlets? stomsf CA - San Francisco Bay Area 1 01-24-2007 06:55 PM
Static on the 12V Outlets airpolgas Audio and Electronics 11 04-02-2006 12:45 PM
Speaking of power outlets. How many are there? exhuman Prius Main Forum 4 03-31-2005 01:32 PM
Oil change at chain outlets pepa Prius Main Forum 18 01-21-2005 09:31 AM
