| Audio and Electronics This is a discussion on Force navigation sync? within the Audio and Electronics forums, part of the Toyota Prius Forums category; Hello, I tried some searching, so I hope this isn't something that is covered over and over again. But, is ... |
| Join Date: Aug 2005 Location: Manhattan Beach, California
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hello, I tried some searching, so I hope this isn't something that is covered over and over again. But, is it possible to force the nav to try and find your actual location? A couple times a week I'll be driving along and it will be off by miles. After a while it will find itself but it doesn't always happen when the car is turned off and it doesn't always happen quickly. I've made a trip from southern california to northern california and had it be off the whole time. Unless I was somehow in the Pacific Ocean The only thing I could find was the calibration but it's not like it's off by a block, it has been off by 60 miles after long enough time. Thanks a ton |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | That's never happened to me. If I have moved the map from where I am, I press the MAP button and that snaps it back to my location. |
| Platinum Member Join Date: Mar 2006 Location: Minnesota
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Very odd problem... luckily something i haven't had to deal with. I don't know if there is a way to force it to update your position. However, i can propose a few ideas as to why this might be happening: 1. Your actual location is correct, there's something wrong with your map CD (unlikely) 2. The nav system takes as input your speed, direction (forward/reverse), and compas direction. One of these could be off. for example, if your compas is off by a little bit, you would gradually shift off the street (although the nav would try to match you to the nearest street). It might be easier to document the problem (for example, photographs of the nav showing you in the middle of the ocean when, infact, you are not) and take it to your dealer... that is something that should be covered under warenty as defective. |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I haven't noticed it since the 4.2 upgrade, but there was a stretch of Route 74/76 in NC where I'd be show driving off the road by about 100 yards. The same thing happened in the mountains of PA and WV at least twice. In all cases, eventually I'd be 'correct' again. However, 60 miles is far beyond that issue. It's like your GPS antenna is turned off, and the 'dead reckoning' that's a fallback isn't very supportive. One of the service menus includes a list of 'visible' GPS satellites. I don't have directions handy, but if you can get them, next time you seem 'off' check to see if you have any GPS assistance...
__________________ 2004 Seaside #9/BC as of 1/3/2004 Oil now any GOOD synthetic I can get on sale Goodyear TripleTred 195/65R15 tires since 5/19/05 ![]() 80,000 miles as of 8/22/2008 |
| Senior Member Join Date: Mar 2006 Location: Cambria, CA, USA
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | You didn't say what year you have. The nav systems may differ. Check if you see the "GPS" letters up near the upper left corner of the map view. This means the nav is properly receiving satellite signals. If they're not there, then it uses dead-reckoning to try to determine your position. (Dead reckoning uses time/distance. It counts tire revolutions.) |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Boy I have to say you can not force a GPS to "sync" you are either getting a signal or you are not! I have waded out hip deep in the woods to get a signal to end a dispute over position. The dead recoining in the Prius uses the speed tire rotation and inertia and turning monitors to supplement the GPS. Trust me if you are driving through a forest with tall Douglas Fir on other side or the "canyons" of NY city your may not be the greatest. There dead recoining cuts in and it is a god send. Get it?
__________________ Belle, a Millennium Silver '04 BC #9 "Becoming one with my Prius, ICE on ICE off" Belle has been passed on to my daughter. I have a new silver Prius 08. No name yet we have just met but not been introduced. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have an '05 with the original nav, I think 4.1? I'll keep an eye out to see if the GPS logo is up when the problem is happening. I've noticed the problem when I was travelling through tall trees in the Northern Sierras, but I've also had it happen driving through the forest known as "the 405" in Los Angeles, no interference around. The car will continue moving and trying to stick to roads but it's no roads near me so it hops from road to road or sometime just goes through a large empty space. Meanwhile I'm heading straight up the 405,5,99. The nav saves me, but some times it lets me get into trouble because I rely on it too heavily and once it goes down I'm hosed |
| Join Date: Oct 2005 Location: a gallon south of Microsoft
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(KTPhil @ Apr 4 2006, 11:57 AM) [snapback]234817[/snapback]</div> Quote:
There are 2 navs and this info is for the more popular, so if nothing is as I said, ping us back. Regards, Mike
__________________ coolest prius I ever worked on....department of corrections, EV for silent run, DRL disabled, passenger seat removed, shotgun mount installed. [size=1] | |
| Senior Member Join Date: Mar 2005 Location: Colorado
My Car: 2008 Prius Package: #6 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Do you have something blocking the GPS antenna? The antenna is just forward of the center speaker in the dash. If you place a radar detector or something similar in that area you may be blocking antenna reception. |
| 2007 Prius, Bluetooth/Motorola L7 Sync Problem | alphlulu | Care, Maintenance and Troubleshooting | 8 | 04-18-2008 04:50 PM |
| Palm 700p Sync'ing | Tatania | Audio and Electronics | 3 | 05-09-2007 01:29 PM |
| 06 Prius Calendar/memo sync? | pgorbas | Prius Main Forum | 0 | 03-03-2006 11:44 PM |
| SKS and two 2005 Prius-Sync. the keys? | laserbill | Prius Main Forum | 8 | 10-21-2005 05:58 PM |
| Maintenance Required Light Out of Sync. | stuhillman2004 | Care, Maintenance and Troubleshooting | 11 | 03-25-2005 10:42 PM |
