| Audio and Electronics This is a discussion on Prius Phonebook Issues within the Audio and Electronics forums, part of the Toyota Prius Forums category; I was able to get the phone connected to the car using John's instructions (thanks BTW I was not able ... |
| Senior Member Join Date: Feb 2005 Location: Fort Hood, TX
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I was able to get the phone connected to the car using John's instructions (thanks BTW I was not able to find any instructions in the manual). However, when I would try to transfer the phonebook the phone would disconnect and the car would just sit there until I hit the cancel button. Is this function not working? Also, when I try to select a phone book to enter phone numbers it says it is empty and will not let me do anything. Is there instructions somewhere on how to enter numbers in the speed dial and phonebook?
__________________ Two Prii Family - '05 Salsa Red BC#6 (Mine) and '05 Driftwood BC#6 (Wife's) Best Tank: 89.398 MPG (372 mi) - all city Worst Tank: 29.5 MPG (131 mi) - one flat tire Current Year: 56.826 MPG Best Yr: 58.242 MPG (2006), Worst Yr: 51.237 MPG (2005) Lifetime Avg: 54.911 MPG (31799 mi) Savings based on mid-size Avg since 2/05: $3,447.50 ($7,101.94 for both Prius) Dual Prius MPG, Expense, ROI, and Emissions tracker (updated 8/19/9/07) Single Prius MPG, Expense, ROI, and Emissions tracker (updated 9/15/2007) Solar Panel Stats: Overview Power Yield |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Tadashi @ Jul 7 2006, 11:03 PM) [snapback]282853[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I have Cingular but maybe they did the same thing. How do I setup numbers in my phone book so I can tell the car to dial? I can dial if I goto the map and use the phone number assocaited with the location but that is very cumbersome. |
| worcester gal Join Date: Aug 2006 Location: maine
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Tadashi @ Jul 8 2006, 08:48 PM) [snapback]283171[/snapback]</div> Quote:
any one know whats up ?? | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(jan @ Aug 7 2006, 07:05 PM) [snapback]299357[/snapback]</div> Quote:
Although the sequence was a little criptic at first, it worked well, just slow. Tadashi, here is the sequence that works in my '06 to transfer numbers one at a time - Get to the Telephone screen and ensure the phone is connected to the car via BT Settings Phone Book Transfer Data Pick one of the groups (you can name them elsewhere) Add To Then on the phone: Select your entry you want to transfer Menu Scroll down to 'Send" and select it If you car is not appearing in the list of object select [Look For Devices] (you'll only have to do this once) Select your car's device name It will connect and send the object To create a number in your phone book, do the following - Phone Book Register Name Enter the Name then press OK TEL1 Enter the number then press OK Group Assign it to a group To assign that number to a Speed Dial so you can access it while the car is in motion do the following - Settings Speed Dial Register Select an entry Touch the phone number showing for the entry (this is the part that is not obvious) Select a Speed dial group Touch the Speed Dial location to assign it to Now you can dial that number via Speed Dial while the car is moving Good Luck. Let us know if any of this does not make sense or if you have problems. Joel
__________________ Seaside '06 Package #6 Leather added Full Clear Bra package Mud Flaps, Side moldings, and Coastal receiver hitch Purple Wire switch and Sirius Here2Anywhere Receiver installed behind smoked window door | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I thought this was a real interesting link on the Razr "Ask Dave Taylor", another guy out there pitching Prius when he can. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I also have Cingular and a RAZR...no one helped me....but I finally figured out that I could send one number at a time to the phone book....then moved 17 to Speed Dial and Voice Tagged a bunch. I'm glad I took the time. I love the BT feature!! terri Later, a local Cingular dealer confirmed that with the RAZR the transfer has to be one number at a time. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Voice tags ... what does that mean ... can you use the sound system in the car to initiate the calls ??? Sorry for the dumbness but I just got my prius day before yesterday and I'm still learning. Thanx ... Ed |
| Artist In Residence Join Date: Jul 2006 Location: Newton, MA
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 5 | Yes, if you have the bluetooth feature then you can use the voice recognition system to dial calls. You have to record yourself saying each name that you want to be able to dial, which seems odd to me, since the Nav can recognize when you say street names. Full details of how to do it are in your manuals. |
| Prius phonebook program? | bradturner32 | Audio and Electronics | 3 | 07-30-2007 02:49 AM |
| Blackberry Phonebook Bluetooth Laptop issues 2006 | reefers | Prius Main Forum | 3 | 02-27-2006 12:15 PM |
| prius bluetooth phonebook | asinn | Audio and Electronics | 1 | 10-10-2005 10:23 PM |
| New problem with 6601 and Prius (phonebook) | mcitron | Audio and Electronics | 0 | 12-24-2004 09:48 PM |
| prius phonebook and motorola v710 | bokuwasaiko | Audio and Electronics | 3 | 12-16-2004 08:33 PM |
