| Audio and Electronics This is a discussion on Recommendations for speaker upgrade? within the Audio and Electronics forums, part of the Toyota Prius Forums category; Hi I have the non-JBL, base system, and I really want to upgrade it. I've seen people here recommend Infinity ... |
| Senior Member Join Date: May 2006
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi I have the non-JBL, base system, and I really want to upgrade it. I've seen people here recommend Infinity 6010cs or even the Infinity Kappa's 63.7i or 62.7i (what's the difference?) I want something that will sound better than what's in there now, and is easy to install. Also, I'd really rather not have to install an amp, but I am willing to replace all the speakers. What brand/model would you recommend? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Soylent @ Sep 15 2006, 11:53 AM) [snapback]320199[/snapback]</div> Quote:
I just had my local CircuitCity replace my non-JBL speakers with a pair ofPolkAudio db650 (6.25") in the rear doors, and a pair of Polk's db6500 (6.25" in the front doors plus A-pillar tweeters), and a complete DynaMat doorkit in the front, and small speaker-area kit in the rear doors. As of yet, I haven't installed an amp. Alas, the sound, to my ears, is the same. At first anyway. The mids are definitely more apparent and the bass is much cleaner, but other than that? I'm not sure my new speakers were worth it. The DynaMat insulation has given the front doors a slightly more solid "heft" to the weight of the doors, and people I've talked to swear it helps with road noise (not that a Prius needs it) and with heating/cooling. So that alone may have helped the sound, and in particular, the bass. Now I'm looking at installing the smallest possible four-channel amplifier, hopefully under the front passenger seat. Many of the "professionals" and friends I asked recommended that I put the amp in with the speakers; I wanted to see if the brand-name speakers alone would give better sound. Guess not. So I'll have to see what the amp does for me now. I definitely don't want to put it in the back, I need that space often. So I'm hoping my boys won't kick the amp if I put it under a front seat! Good luck with your system, I hope you have better luck! | |
| Senior Member Join Date: Aug 2006 Location: Raleigh, NC
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Soylent @ Sep 15 2006, 02:53 PM) [snapback]320199[/snapback]</div> Quote:
For the front speakers, you will need component speakers (where the woofer and tweeter are completely separate and installed in different locations). Each component speaker set comes with a crossover to split the music between the speakers. Both speakers will be installed in the front doors in the factory locations. The Kappa 60.7cs is the equivalent component speaker. The woofers are the same as the other Kappas, but it has separate tweeters to fit up near the dash. The tweeters are also sold separately as Infinity Kappa 10.7t. If you have basic wiring skills, you can do it yourself. Search for "speaker relacement guide" by ~sparky~. It's excellent and tells you everything you need to know for the rear speakers. I have not seen one for the front speakers, but I took some photos when I did mine and maybe I'll be able to post them sometime if there is interest (just dropped off the film). I also did double layers of Dynamat Xtreme in the doors. I'm not sure how much that cuts down on road noise but you can certainly tell the difference just rapping your knuckles on the doors - it's now a solid thud instead of the hollow ringing. There are many choices of speaker brands and models. I chose the Infinity Kappas because they seemed to be the most commonly recommended. Others will have other opinions which may be just as good. Just get those factory speakers out of there. You're listening to cardboard. Almost any quality aftermarket speakers will be better. I noticed a HUGE difference in sound clarity with mine. Incidentally, I bought my speakers through amazon and the Dynamat from ebay. Hope this helps.
__________________ PA --- Took delivery Aug. 4, 2006: 2006 Seaside Pearl Pkg. #4 (side & side-curtain airbags, VSC, SKS, backup camera) w/beige interior mudguards, cargo net, rear bumper protector, & Toyoguard dealer profit-protector Infinity Kappa speakers (60.7cs & 62.7i) w/Dynamat Xtreme | |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 12 | <div class='quotetop'>QUOTE(PA @ Sep 15 2006, 08:08 PM) [snapback]320306[/snapback]</div> Quote:
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rangerdavid @ Sep 15 2006, 08:34 PM) [snapback]320320[/snapback]</div> Quote:
| Senior Member Join Date: Sep 2005 Location: Tampa, FL
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | <div class='quotetop'>QUOTE(papawithprius @ Sep 15 2006, 07:29 PM) [snapback]320291[/snapback]</div> Quote:
Pretty much any decent speaker will sound better than the average factory setup. Sometimes, in a "Premium" system, the manufacturer actually does use some pretty good speakers, and you won't get much improvement unless you redo the WHOLE system. Anyway, best way to decide on a speaker is to go and listen to them all yourself. Bring a couple of CD'd with you of the types of music you listen to, the more variety the better. Any good shop will let you listen to the speakers for as long as you need to decide. Try as many as you can in one day, as it is easy to forget after a day or two. Once you get your favorite(s), listen to those again to narrow it down to one or two, and there you go.
__________________ -- Bjorn -- 2007 Dark Amethyst Lincoln Navigator L 2005 Magic Blue Volvo XC90 T6 AWD Coming in 2009: Chrome Orange Lotus Exige S *** 2006 Classic Silver Metallic, Package 7+Leather *** sacrificed itself to keep me safe Thanks Prius. My Prius Mod Website | |
| | #7 | ||
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(PA @ Sep 15 2006, 05:08 PM) [snapback]320306[/snapback]</div> Quote:
Just about every maker of decent home speakers at and below the $2500/pair price point is a 2-way (2-1/2 way being a special type of 2-way). Very few (probably less than 1%) of people own a system with speakers good enough (and expensive enough) to justify a 3-way design. Such a system would cost as much as most people's cars. There's a good reason why the best speaker in almost every high-end car audio manufacturer's line (Focal, CDT, Diamond) is a 2-way component speaker, and not a 3-way coaxial speaker. A 6.5" woofer can extend high enough that there is no need for a driver to reproduce frequencies below that of the tweeter. Look at the $6k/pair Thiel CS3.7. Three-way design with a five inch midrange driver. Now do you think your car needs a 1" midrange and 1/2" tweeter? Maybe Jim Thiel was just cutting corners on his $6k speaker when he left out that extra driver that your $100 Kappa 63.7i has. Quote:
__________________ 2009 Toyota Camry Hybrid Black (hers) JBL Audio, Bluetooth, Moonroof, Alloy Wheels, Pink Fuzzy Dice on rearview mirror 2005 Driftwood Pearl Pkg #6 (mine) Katzkin Leather Interior Diamond Audio D661s Component Speakers JL Audio 8W3 Subwoofer JL Audio CleanSweep CL441dsp MTX Thunder 564 Amp 4x100 watts MTX Thunder 421D Amp 1x300 watts OEM Sirius Tuner 2004 Super White Pkg #9 (hers) - sold | ||
| | #8 | ||
My Car: 2006 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(priusenvy @ Sep 16 2006, 05:21 AM) [snapback]320466[/snapback]</div> Quote:
| | #9 | ||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(priusenvy @ Sep 16 2006, 04:21 AM) [snapback]320466[/snapback]</div> Quote:
current prices. kappa63.7i $95, kappa62.7i $75, kappa10.7t $55 ref6010cs $95, i believe this is a pair of ref6012 ($44) and a pair of ref1011t ($33 different store) also i think the kappa version of this is kappa60.7cs ($139) basicly it all depends how much your wanting to spend. and if possible always listen to them first. some people won't notice a big enough difference between two speakers to make the more expensive one worth it, some will. | ||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | I would suggest spending an amount of money on your speakers that correlates to the amount of time you spend in your car. Since I spend a minimum of about 2-3 hours each day driving, the stereo is crucial. Keep that in mind. Now you also need to balance that with how well you can hear the differences in speakers. Listening to a pair of speakers mounted in a wall at the local electronics store is not an accurate representation of how they will sound in your car, but if all of htem are similarly mounted then at least that will be minimized. So make sure you can tell a difference between the speakers. If you can't tell a difference between a $50 pair and a $500 pair, then it makes no sense to buy the more expensive ones. However, if you listen and the $500 pair just blows the other ones out of the water, then it may be worth it... As for the 3-way (and even 4-way) speakers, they are really not worth it. There is not really any benefit to it. A well designed speaker will have the minimum of drivers necessary to reproduce accurate sound. there are always compromises in splitting the sound between the different drivers. To do that really well costs a LOT of money. Get a decent 2-way or components. A competently designed set will outerperform any 3-way speaker. |
| Best speaker upgrade for $200 ? | ystasino | Audio and Electronics | 11 | 01-10-2008 08:50 PM |
| Non-JBL Speaker Upgrade? | kathrynne1 | Audio and Electronics | 7 | 03-30-2007 05:21 PM |
| Best Non-JBL Speaker Upgrade? | Sillyboy | Audio and Electronics | 32 | 03-15-2007 07:52 PM |
| Dynamat or not w/ speaker upgrade | ScottY | Audio and Electronics | 2 | 07-20-2006 04:59 PM |
| Speaker Help | XravenX | Audio and Electronics | 4 | 02-28-2005 12:17 AM |
