Audio and Electronics This is a discussion on Unlocking with fob within the Audio and Electronics forums, part of the Toyota Prius Forums category; Howdy 9G-man Owner's Manual, page 32, in the right column of the page. May take a couple or three tries ...
Old 07-05-2007, 02:24 PM   #11
Charles Suitt
Charles Suitt's Avatar
Send a message via Yahoo to Charles Suitt
Howdy 9G-man
Owner's Manual, page 32, in the right column of the page. May take a couple or three tries to get it the way you want, but it will work.
CIAO
Charles Suitt is offline
Old 07-05-2007, 02:55 PM   #12
Vagabond
Vagabond's Avatar
Send a message via AIM to Vagabond Send a message via Yahoo to Vagabond
My manual lacks these instructions
Vagabond is offline
Old 07-05-2007, 03:43 PM   #13
hschuck
<div class='quotetop'>QUOTE(Kentucky Joe @ Jul 4 2007, 06:54 AM) [snapback]472858[/snapback]</div>
Okay, but I don't think the original question has been answered. I'd like to be able to press the unlock button on the fob only once and have all 4 doors unlock. The manual says this is possible but does not describe the procedure. If Evan's procedure is only for a Smart Key (which I do not have) then what can I do? Thanks! -Joe
The fob must be reprogrammed by a dealer using the scantool per the "customizable features.pdf" linked-to in this thread. http://priuschat.com/How-to-change-customi...ius-t35592.html
"Function to unlock the driver’s door by pressing the unlock button of the transmitter once and to unlock all the doors by pressing it twice. In the OFF setting, pressing one time makes all the doors unlocked." [/b]
hschuck is offline
Old 07-07-2007, 05:15 PM   #14
9G-man
QUOTE(Kentucky Joe @ Jul 4 2007, 09:54 AM)
Could you please reference where the manual says this.
<div class='quotetop'>QUOTE(Charles Suitt @ Jul 5 2007, 02:24 PM) [snapback]473565[/snapback]
Howdy 9G-man[/b]
CIAO
[/b][/quote]
Incorrect. The above owners manual referrence pertains to smartkey functionality changes, and that's not what the original question in this thread was..........the original question was how to change the unlock button funtion on the key-fob. And there is no reference to that in the owners manual.
9G-man is offline
Old 07-12-2007, 07:38 PM   #15
1fixitman
Send a message via Yahoo to 1fixitman
<div class='quotetop'>QUOTE(Vagabond @ Jul 5 2007, 02:55 PM) [snapback]473583[/snapback]</div>
In my 05 manual publication number OM47509U Part Number 01999-47509
This is on page 31 on the right side but it is for smart key.
It states push the lock button toghther with the panic button on the smart key for 5 seconds with the hybrid system off, the setting for door unlocking will change as follows:
1. Driver door unlocking mode. smart unlock on drivers door will unlock only the drivers door. Unlock the passenger or back door will unlock all the doors
2. All doors unlocking mode. smart unlock on either front door or back door will unlock all doors.
3. Single door unlocking mode. the drivers door of havk door on which you perform smart unlock will unlock. HOWEVER smart function for passenger door will unlock all doors.
I know this is only for the smart key holders but it helps them too.
D Rock
D Rock
Removed wheel trim rings($0), Heat shields(mostly use windshield one since I have tint now) all the way around($120), BT Plate($165), EBH($39), 195/65 R15 Bridgestone Turanza LS-T tires at 42/40(now discontinued $340), Weather tech window vent shields($120), Zaino wax system($93), Scan Guage II($149), Nushield MFD screen protector($19), MFD hood(sun glare reducer $34), Fumoto 103N oil drain plug($21), Daryl the EV nut's Magnificient SUPER LED upgraded interior lights($434), Blocked upper grill($1.42), 35% window tint except front windshield LLumar brand($175), Mud flaps($36) what is next LOL?
1fixitman is offline
Beeping when using Smart Key for unlocking spacey_ts Prius Technical Discussion 11 08-25-2007 08:35 AM
Is this guy close to unlocking the 2006? YBLee Prius Modifications 6 01-15-2007 08:50 PM
Central unlocking micaela Audio and Electronics 1 07-12-2006 10:26 PM
Unlocking 4 doors in '06 krainium Prius Main Forum 10 05-26-2006 08:38 PM
Unlocking all doors with SKS (Was: Deleted) tracysbeans Prius Main Forum 73 01-22-2006 03:15 PM
