Audio and Electronics This is a discussion on 2005 Prius aftermarket stereo install pdf. within the Audio and Electronics forums, part of the Toyota Prius Forums category; This may help some of you planning on doing an aftermarket stereo install in a 2004-2007 Prius. This includes instructions ...
2005, install, pdf., prius, stereo
Old 06-20-2008, 03:43 PM   #1
F8L
Collecting Data on Nature
F8L's Avatar
Nominated 1 Time in 1 Post
Friends: 15
Default 2005 Prius aftermarket stereo install pdf.
This includes instructions for the 68ohm resistor as well.
Special thanks to the guys at Metra Electronics for their help and instructions.
File Type: pdf INST99-8213 2005 Prius deck install.pdf (601.5 KB, 257 views)
F8L is offline
Old 06-20-2008, 07:38 PM   #2
Presto
Has his homepage set to PC
Default Re: 2005 Prius aftermarket stereo install pdf.
Good post. This should be stickied or something.
Presto is offline
Old 06-20-2008, 07:59 PM   #3
F8L
F8L's Avatar
Friends: 15
Thanks Presto
If you choose to keep the factory stereo installed and install an aftermarket stereo under the facotry unit (in the storage pocket) you can bypass the 68ohm resistor mod by purchasing the Best Kits harnesses BHA-1761 and BHO-1761. The BHA-1761 harness will wire up to your aftermarket deck and plug into the factory harness. The BHO-1761 harness will splice into the BHA-1761 and allow you to power up your factory deck as well. This keeps the system intact electronically speaking and will keep you from having to do the 68-ohm resistor mod and will not set codes or warnings for the A/C connection issue. *NOTE* upon first firing up the system you may see a warning but it goes away after a bit of driving and I have not observed any issues since last winter when I did the install orginally.
If this post seems helpful then I'll go over my exact wiring and try to take a few pics and post em up to make the install more clear.
F8L is offline
Old 06-21-2008, 02:50 AM   #4
kcopen
Damn man this is tremendous, if i was a little less lazy I might be inclined to actually try this myself. Still this will be a useful reference to whoever installs my system. Thanks man.
kcopen is offline
Old 06-21-2008, 03:05 AM   #5
F8L
F8L's Avatar
Friends: 15
LOL, I didn't think it would be a big deal but I hope it helps someone.
The alternative to installing in the factory stereo location can be found in THIS thread:
F8L is offline
Old 06-21-2008, 02:32 PM   #6
kcopen
yeah it's probably not but after dealing with some local install clowns it'll be good to have some documentation.
kcopen is offline
Stealth install an aftermarket stereo in Prius F8L Audio and Electronics 28 09-13-2008 04:42 AM
2008 Prius stereo removal for DICE install - help! keytohwy Audio and Electronics 6 04-25-2008 01:43 AM
Problem with aftermarket stereo install. F8L Audio and Electronics 3 10-16-2007 02:15 AM
Aftermarket CD Changer Install jlwhite Audio and Electronics 4 05-23-2005 06:54 PM
Install Bluetooth Car Kit (Aftermarket) jlowen Prius Main Forum 0 12-31-1969 07:00 PM
