Audio and Electronics This is a discussion on IN DASH Car2AUX within the Audio and Electronics forums, part of the Toyota Prius Forums category; I bought the IN DASH Car2AUX-TOY but have not installed it yet. Has anyone installed this or similar unit? The ...
car2aux, dash
LinkBack (1) Thread Tools
Old 07-10-2008, 08:10 PM   1 links from elsewhere to this Post. Click to view. #1
whoda_thunk_it
whoda_thunk_it's Avatar
Package: #1
Default IN DASH Car2AUX
The unit plugs in where the CD changer would. Is it possible to do this without taking out the entire dash and display or can you do it by taking out the glove boxes?
Based on the video I found here, taking out the glove boxes doesn't scare me much. Taking out the entire dash and display to get at the stereo is something I don't think I want to do to my new-born...at least not quite yet.
thanks
Jeff
whoda_thunk_it is offline
Old 07-13-2008, 12:27 AM   #2
Joekc
Joekc's Avatar
Default Re: IN DASH Car2AUX
thanks
Jeff
Yeah, it took me eight months to get up the nerve to do this (XM install):
I have read of people who have accessed the back of the radio by yanking the vent next to it (by the glove box) and maybe removing the glove box, but I'm not sure on that last part. It seems the issue is getting one's hand behind the radio in such a fashion as to get enough leverage to insert the plug firmly. Just out of curiosity, where will the stereo wire go after it leaves your dash?
Joekc is offline
Old 07-16-2008, 11:27 PM   #3
whoda_thunk_it
Package: #1
On Saturday, I removed the lower glove box, and the passenger side vent panel and was able to insert the plug fairly easily. Unfortunately when I hit the "disc" button to be able to hear my input I heard nothing, and the displat showed "no disc".
I messed around, uninstalled, reinstalled and still no luck.
Eventually I unplugged the existing plug and left in the CAR2AUX plug. The radio worked, the new input worked, (the sound was much better than with FM transmitter I used to use) but the MFD showed "audio off" so there was no way to know which station was tuned in, it was just next programmed station. I emailed this info to Grom audio. Late last night I got an email saying thay they figured out the problem and were sending me a new chip set.
Once it arrives I'll install and report on the outcome.
Since there are no other mentions of this device on the forum I guess I'm the lab rat.
Old 07-22-2008, 02:47 PM   #4
jbors
Just make sure you contact our support form on gromaudio.com
We fixed that glitch and now everything works fine.
BTW: There is better way to install adapter as shown in here:
youtube.com/watch?v=ll4HIwQuHT4
jbors is offline
Old 07-24-2008, 12:14 AM   #5
whoda_thunk_it
Package: #1
Well, it is finished.
The new chip arrived today. It was simple to replace, and in a few minutes I hade the unit plugged in and working as it is supposed to work.
I put everything back together and tried it again, and it didn't work. So I once again detached the big pain-in-the-butt wiring harness, unplugged and re-plugged the unit and it started working again. I then reattached the wiring harness and put the AC vent back in.
This unit is actuall easy to install if you only have to do it once.
This video link from jbors shows exactly what you need to take apart to install the unit. The most difficult part is removing the wiring harness and reattaching it. The video says you need a Phillips screw driver for this, but in doinig it more than once I found that a socket wrench worked better. I took my 11mm socket and the extension shaft and taped it on to the end of a straight blade screw driver that fit into the end of the extension.
This made it much easier to hold on to the bolt, and hold it in place to get it started and tighten it. I guarantee this will make taking out and reinstalling the wiring harness so much easier. Getting it out of the way in the glove box area and back again is another story...just take your time.
As for Gromaudio.com, my emails were always answered quickly, and they sent me the replacement chip quickly once they knew what was wrong. When I first searched this forum for info about this unit I didn't find anything, but a few nights ago cam across a thread where someone discribed the same problem over a year ago, so I'm not sure why it hadn't been solved before mine was shipped to me.
I hope this helps make installation of this or other similar units easier. If anyone has questions I'll be happy to tell you what I can.
Jeff
Old 07-26-2008, 05:15 PM   #6
cramam
cramam's Avatar
Whoda Thunk It, I saw in your sig that you installed the Coastal 2" receiver. How hard was it? Does it seem sturdy and are you happy with it? Would like something to carry my bike.
cramam is offline
Old 07-28-2008, 02:17 PM   #7
whoda_thunk_it
Package: #1
Installing the hitch was pretty easy. It took me about 45 minutes on a wet, muddy driveway. If you can, find a way to park (off a curb or slanting driveway, or use ramps) so the back end is higher off the ground it will go much faster. My biggest problem was getting leverage to remove the factory-installed bolts where you attach the hitch. I only had about 2" of clearance over my chest when I was on my back under the car. The directions they supply are good, at least I don't remember having any issues with what they said.
I only use the hitch for my bike rack and two bikes. It seems sturdy, but I have only used it for a total of about 8hrs driving on pretty smooth roads so far. I didn't like how far out from the car the bikes sat, so I plan to cut off the end of my bike rack to allow me to insert it farther into the receiver. It is 1/2" too long to allow me to use the pin in the hole I want to use. This is a problem with my rack not the hitch.
I think this is a much better option than using the 1 1/4" and then adding a 2" adapter which I had on the Matrix I used to drive.
Old 07-30-2008, 05:26 AM   #8
eyesmell
eyesmell's Avatar
I just ordered this thing too. It's a little concerning that someone had this issue back in 07 and u still recieved a faulty unit a year later. I really hope mine gets shipped with the correct "chip". I'll repost when I get it installed and let everyone know how it went.
eyesmell is offline
Old 07-31-2008, 07:22 PM   #9
eyesmell
eyesmell's Avatar
Well I got mine in today, and got it installed in about 20 minutes. First time I tried it I turned my car on and it didn't work, so I unplugged and plugged it back in (this time I heard a little snap, probably from the tab locking into place), turned on my car and all was well. Unlike Whoda, I just used a phillips screw driver to unscrew that huge block of wires. Moving it over into the glove box area was a HUGE pain in the ass, but I eventually pulled it off.
One of the times I turned my car on, the MFD displayed No Audio, and when I pressed Disc it showed No Disc, but I turned my car off and on again and it worked.
I just hope it keeps on working.
All in all, you can't beat the price. I would recommend this product. It does what it's supposed to.
eyesmell is offline
Old 08-01-2008, 01:30 AM   #10
CCC712
CCC712's Avatar
Does the Car2AUX work with the iPhone (Edge not 3G) and does it lock out control of the ipod? Can you change playlists on the head unit or just songs?
CCC712 is offline
LinkBack to this Thread: http://priuschat.com/forums/audio-electronics/50727-in-dash-car2aux.html
YouTube - Toyota Prius 2008 iPod installation This thread Refback 08-14-2008 01:26 PM
My In-Dash Car PC project TheForce Prius Modifications 74 07-27-2008 11:33 AM
New dash look for '06? BertinNC Prius Main Forum 10 01-13-2007 05:29 PM
dash mat cover janice45 Private Sales 0 12-30-2006 07:33 PM
Dash Mat shimma Prius Main Forum 5 12-02-2005 08:50 AM
Mac Mini In Dash gmeyer Prius Modifications 1 10-17-2005 01:35 AM
