Audio and Electronics This is a discussion on DIY Aux-In for Base Prii for under $100 within the Audio and Electronics forums, part of the Toyota Prius Forums category; Here's my solution to Aux-input in my 07 Base Prius. I'm by no means an expert at this stuff, and ...
aux, aux-in, input, iphone, ipod
LinkBack (11) Thread Tools
Old 08-01-2008, 07:56 PM   11 links from elsewhere to this Post. Click to view. #1
eyesmell
eyesmell's Avatar
Default DIY Aux-In for Base Prii for under $100
Here's my solution to Aux-input in my 07 Base Prius. I'm by no means an expert at this stuff, and some people might correct me on some steps or explain how I could have done things better/cheaper/smarter etc...
I welcome any criticism, I just thought this may help some people looking to add aux-in to their Prius
Ingredients:
Total: $77.98 (plus tax & shipping)
Tools:
  • Phillips Screwdriver
  • Drill
  • Soldering tool
Cook Time: About an Hour
Directions:
First step is get your GROM Car2Aux installed and working properly. This video shows how it's done:
It took me two tries and about 20mins to get this installed.
(If you're attempting this, don't assemble the dash just yet, you'll still need to get behind there...)
After I got this unit installed, tested that it's working properly, I took the head phone cable and cut it in half with some wire cutters. The reason I choose this wire is because it had removable sleeves that you can screw on and off. After cutting the cable, I removed the sleeve and gold spring from the female end and set them aside for later.
I choose to put my aux jack in the compartment below the radio because I figured it would be easy to stash cables and iPod in there, and in case I made some sort of tragic mistake, it wouldn't be very noticable
I drilled a hole just large enough to shove the back end of the female jack through it. (If you're going to attempt this, please please double check behind the box to make sure there arn't any loose cables that may get cut by the drill. In my case there was plenty empty space behind the box so I didn't have to worry too much about the drill bit catching anything BUT YOUR CAR MAY BE DIFFERENT) It took me a bunch of tries because I didn't want to make the hole so big that the whole thing falls though. I finnaly got it just big enough so that the jack fit snugly in it and so that it won't come out if I pull too hard on a cable or something. I then ran the sleeve back up the loose end of the cable and screwed it back in as tight as I could to keep everything secure. (You can probably substitute the sleeve with a finely threaded nut if you can find one that fits)
I now had to put back the cable that I had cut in half earlier. I stripped both ends and there was only three different colored wires inside, so I matched up the colors and tied them together like so:
Tested to make sure it still works (and it did) and then soldered and taped the whole mess back together.
After all this I was left with two male ends, one from the cable I just patched, and one from the Car2Aux unit, so this is where the coupler comes in. (Initially, if you can find a similar headphone cable with two female ends, you won't need a coupler, but I couldn't so I did) I then coupled? both cables together and tested again, and everything was still peachy.
So I shoved the whole cable mess/car2aux unit behind the lower glove box, above the cabin filter....
...and reassembled the right half of the dash, and I am completly happy with my handy-work... for now
eyesmell is offline
Old 08-02-2008, 03:29 AM   #2
Flying White Dutchman
Friends: 5
Default Re: DIY Aux-In for Base Prii for under $100
i can see on the website its only for the 06 and up prius.
Old 09-09-2008, 09:27 AM   #3
isibrigade
I must say, nice and clean job. Isn't there a cable available that works without all the wire work? Or, perhaps you were being particular with the mounting features.
I just got my GROM in the mail yesterday. I plan to instal this week. Your notes and video were helpfull. I'm thinking I might run the connection to the center console box.
isibrigade is offline
Old 09-16-2008, 10:20 AM   #4
isibrigade
I just bought all that I needed. However, I can't remove the cap from the
$12.99 6-Ft. Stereo Headphone Cable, 1/8" Jack to 1/8" Plug
to prepare for mounting. Is there a way to do this? It seems like they are loctited together or something. I feel like I would break it twisting it apart.
Yes, I purchaced the same one. Thanks.
Old 01-03-2009, 07:29 PM   #5
van-island
Do you think the GROM unit works for the '09? The audio system is basically unchanged from the '08, right?
van-island is offline
LinkBack to this Thread: http://priuschat.com/forums/audio-electronics/51699-diy-aux-in-base-prii-under-100-a.html
DIY Aux-In for Base Prii for under $100 This thread Refback 12-17-2008 12:04 AM
IN DASH Car2AUX ?????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! This thread Refback 12-08-2008 08:44 AM
DIY Aux-In for Base Prii for under $100 - Latest Toyota Prius News - Toyota Prius: Blogs and News - Newsbeet This thread Refback 11-26-2008 04:48 PM
IN DASH Car2AUX ?????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! This thread Refback 11-13-2008 12:36 AM
IN DASH Car2AUX ?????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! This thread Refback 09-14-2008 01:03 AM
Technorati: Discussion about “DIY Aux-In for Base Prii for under $100” This thread Refback 09-04-2008 11:22 PM
Technorati: Discussion about “DIY Aux-In for Base Prii for under $100” This thread Refback 08-18-2008 10:38 PM
YouTube - Toyota Prius 2008 iPod installation This thread Refback 08-14-2008 01:26 PM
Toyota Prius 2008 iPod installation on Technorati This thread Refback 08-12-2008 10:07 PM
IN DASH Car2AUX ?????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! This thread Refback 08-09-2008 11:16 AM
IN DASH Car2AUX ?????? - ?????? - PriusClub.TW Prius,TW,TOYOTA PRIUS,???,Hybrid,???????,????,????? - Powered by Discuz! This thread Refback 08-09-2008 10:36 AM
Base suspension vs Touring JEFNLSA Prius Main Forum 10 04-11-2008 06:50 PM
Is this a Pack of Prii or a Pride of Prii??? PhotoLady Prius Main Forum 20 02-13-2008 07:30 AM
Where is the Knowledge Base RussPete Knowledge Base Articles Discussion 2 11-10-2006 03:13 PM
06 Prius Base up $490 OUscarb Prius and Hybrid News 1 11-07-2005 12:46 PM
Base window tint? dstrout Prius Modifications 3 08-12-2005 06:40 PM
